With earlier versions of the binding the paring process with the scalar thing did not work. Now a scalar thing was discovered automatically and paring worked fine. After paring the thing doesn’t go online. Here is a log with log level INFO. I also tried log level DEBUG an saw the binding creating many channels but there was so many log entries i thought this would show the ERRORs better. If needed I can log on DEBUG again and post it.
Maybe the unsupported
says it all?
2019-03-09 14:35:20.676 [hingStatusInfoChangedEvent] - 'sony:scalar:fcf152a50257' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): unsupported
Full INFO level log:
==> /openhab/userdata/logs/events.log <==
2019-03-09 14:35:15.119 [hingStatusInfoChangedEvent] - 'sony:scalar:fcf152a50257' changed from UNINITIALIZED (DISABLED) to INITIALIZING
==> /openhab/userdata/logs/openhab.log <==
2019-03-09 14:35:15.120 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-03-09 14:35:19.823 [INFO ] [web.protocols.ScalarWebLoginProtocol] - Command map already defined - ignoring: /openhab/conf/transform/scalar-fcf152a50257.map
2019-03-09 14:35:24.761 [ERROR] [protocols.ScalarWebAvContentProtocol] - Exception occurred retrieving the content list for scheme 'fav' and source 'fav:tv?id=1': fav:tv?id=1
java.io.IOException: fav:tv?id=1
at org.openhab.binding.sony.internal.net.HttpResponse.createException(HttpResponse.java:176) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.protocols.AbstractScalarWebProtocol.execute(AbstractScalarWebProtocol.java:108) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.protocols.ScalarWebAvContentProtocol.getChannelDescriptors(ScalarWebAvContentProtocol.java:225) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.protocols.ScalarWebProtocolFactory.getChannelDescriptors(ScalarWebProtocolFactory.java:138) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.ScalarWebHandler.initializeTask(ScalarWebHandler.java:201) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.ScalarWebHandler.lambda$0(ScalarWebHandler.java:162) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2019-03-09 14:35:24.960 [ERROR] [protocols.ScalarWebAvContentProtocol] - Exception occurred retrieving the content list for scheme 'fav' and source 'fav:tv?id=2': fav:tv?id=2
java.io.IOException: fav:tv?id=2
2019-03-09 14:35:25.158 [ERROR] [protocols.ScalarWebAvContentProtocol] - Exception occurred retrieving the content list for scheme 'fav' and source 'fav:tv?id=3': fav:tv?id=3
java.io.IOException: fav:tv?id=3
2019-03-09 14:35:25.405 [ERROR] [protocols.ScalarWebAvContentProtocol] - Exception occurred retrieving the content list for scheme 'fav' and source 'fav:tv?id=4': fav:tv?id=4
java.io.IOException: fav:tv?id=4
2019-03-09 14:35:29.381 [hingStatusInfoChangedEvent] - 'sony:scalar:fcf152a50257' changed from OFFLINE (COMMUNICATION_ERROR): unsupported to UNINITIALIZED
2019-03-09 14:35:29.387 [hingStatusInfoChangedEvent] - 'sony:scalar:fcf152a50257' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
