I think I spotted an error you two might be triggering - wait for the next version. Iām going to be gone for the next 5 days - so Iāll catch up when I get backā¦
I think chopping of last octet an replacing it with 255 will work in 99,9%. So i think this is totally fine.
Anyway an idea for some later optimization:
Maybe you can get a value from org.eclipse.smarthome.network.
The primary subnet of openhab can be defined there via Paper UI > Configuration > System Network Settings. With the IP and subnet mask the broadcast address can be calculated (sure you know this). On the downside i think its not required to set this so most users would not have done it. On the other hand its a dropdown value so maybe the information is there anyway.
With the new Version 2.5.0.201903121651 my Scalar thing is still not going online. Not much i can say about that at this moment so just a big log again. (14MB ziped to som KB). Zip-files are not allowed so after download rename it(delete ā.logā). SCALAR.7z.log (247.8 KB)
Ok it works only when I just turned off the TV. Otherwise after some time it doesnāt work āno route to Hostā. Another problem is that the binding will forget the Mac adress and refresh value after some time. So I have created the TV within a. things file.
I cant see the āno route to hostā error in my logs but it did not work for me too. To test it you have to turn off your tv for more than 5 minutes. You will see the binding is no longer online after that time. I even can hear my tv make a click sound. I think we wait to the next version.
In the meantime i use the integrated WoL Binding āWOL (Wake-on-LAN) Bindingā (binding-wol1 - 1.13.0)
I used autoupdate="false" because sending the WoL packet dosent mean the tv is really turned on. Maybe its unplugged or something. So after sending ON command to the item, wich triggers sending the WoL packet, it stays OFF.
To sync it with the real state of the tv read from the binding it use this simple rule:
rule "WoL_WZ_TV aktualisieren auf SonySimpleIP_Power.state"
Item SonySimpleIP_Power changed
logInfo( "tv_wol.rules", "Rule 'WoL_WZ_TV aktualisieren auf SonySimpleIP_Power.state' triggered" )
WoL_WZ_TV.postUpdate(SonySimpleIP_Power.state)
This updates my WoL item when the tv is going ON or OFF even for instance if the tv remote is used.
Another rule helps me to send an OFF via the binding when i switch of my WoL item:
rule "WoL_WZ_TV zum Ausschalten nutzen"
Item WoL_WZ_TV received command OFF
logInfo( "tv_wol.rules", "Rule 'WoL_WZ_TV zum Ausschalten nutzen' triggered" )
SonySimpleIP_Power.sendCommand(OFF)
Hi, thanks for the new binding. SimpleIP is working just fine. But i got problems with Scalar.
I got it registered with the 4-digit code, but since then it does not connect properly.
Can somebody support?
Attached i have a debug log (some seconds in normal logging, then switched to debug logging at some point)
Are you still around? Iām integrating your sonyaudio into the main sony one (working great so far and it covers SOOO many more devices as well - and itās exposing some issues I had in mine with version handling!!).
I have a quick(?) question for youā¦
When you receive the notification - is the version on the notification always ā1.0ā (seems like it is). Example: if I call setPowerStatus using v1.1 style - the notification I get back is still 1.1 style but the notification itself says 1.0 style. Hereās a bit of the log - you can see my transport calling it with the v1.1 style and both your binding/mine receiving back a 1.0 notification even though itās a 1.1 style:
2019-03-21 14:41:16.769 [DEBUG] [s.i.s.t.SonyWebSocketTransport:174 ] - Sending {"id":16,"method":"setPowerStatus","version":"1.1","params":[{"status":"off"}]} to ws://192.168.1.167:10000/sony/system
2019-03-21 14:41:16.775 [DEBUG] [b.s.i.s.models.ScalarWebResult:94 ] - >>> result: 16, [], []
2019-03-21 14:41:16.775 [DEBUG] [s.i.s.t.SonyWebSocketTransport:201 ] - Response received from server: {"id":16,"result":[]}
2019-03-21 14:41:18.433 [DEBUG] [s.i.s.t.SonyWebSocketTransport:210 ] - Event received from server: {"method":"notifyPowerStatus","params":[{"standbyDetail":"","status":"standby"}],"version":"1.0"}
2019-03-21 14:41:18.431 [DEBUG] [.b.s.i.p.SonyAudioClientSocket:149 ] - Message received from server: {"method":"notifyPowerStatus","params":[{"standbyDetail":"","status":"standby"}],"version":"1.0"}
2019-03-21 14:41:18.432 [DEBUG] [.b.s.i.p.SonyAudioClientSocket:160 ] - Event received from server: {"method":"notifyPowerStatus","params":[{"standbyDetail":"","status":"standby"}],"version":"1.0"}
for now - Iām just assuming the notify format is the same version style as the originating calling version (so if Iām calling setPowerStatus 1.1 - the notification will be a 1.1 style).
The problem you are having is that the device is turned off when you started openHAB and it canāt get information from the TV when itās off. Thatās what Iām trying to solve with creating the device definitions but am not there yet.
For now - turn on the TV, start openHAB and it should come online - once itās online , you can turn the TV on/off whatever and it should remain online. Just needs to be on when the binding is first starting up
As I said - this should be a bit temporary until Iāve got the definition thing the way I want itā¦
Just to let everyone know - the next update is pretty darn big. Iām integrating the sonyaudio stuff (websocket connections) and Iāve learned ALOT about the sony api and what I may have been doing wrong with it (mainly with the various API versions). However - itās taking me awhile to get through everything - expect an update maybe next week (or the next).
Note: the update will hopefully fix the WOL thing as wellā¦
Thanks for your reply. Unfortunately not working.
I turned on the TV and restarted OH2 completely, but still the same issue.
I unregistered OH as remote control restartet everything and reconnected and now the same issue.
Here from my logs (not in debug):
2019-03-22 08:39:08.439 [hingStatusInfoChangedEvent] - 'sony:scalar:mysonytv' changed from OFFLINE (COMMUNICATION_ERROR): Access Code requested. Please update the Access Code with what is shown on the device screen to OFFLINE (COMMUNICATION_ERROR): Storage doesn't exist.
2019-03-22 08:39:09.574 [me.event.ThingUpdatedEvent] - Thing 'sony:scalar:mysonytv' has been updated.
2019-03-22 08:39:09.578 [hingStatusInfoChangedEvent] - 'sony:scalar:mysonytv' changed from OFFLINE (COMMUNICATION_ERROR): Storage doesn't exist. to ONLINE
2019-03-22 08:39:25.845 [hingStatusInfoChangedEvent] - 'sony:scalar:mysonytv' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Storage doesn't exist.
2019-03-22 08:39:26.866 [me.event.ThingUpdatedEvent] - Thing 'sony:scalar:mysonytv' has been updated.
Edit:
Ok the issue might be somewhere else. I completely removed the scalar thing, but these log are still coming regularly.
2019-03-22 08:43:46.092 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ScalarWebHandler tried updating the thing status although the handler was already disposed.
2019-03-22 08:43:47.182 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ScalarWebHandler tried updating thing sony:scalar:mysonytv although the handler was already disposed.
Edit2:
After a restart the thing seems to be really gone, but after adding the thing again, to problem reoccours just like before
@andirs
Thanks - Iāll need to look harder into that error then - something is leaking out to the thing and pulling it off line. Iāll see what I can do. As for the messages occurring - thatās something I have fixed in my version that youāll get in the next (wasnāt properly cleaning up a thread)
Just a quick update - still working on the code. Iāve had to do some extensive reworks based on some (wrong) assumptions I made with the prior code and Iām still testing through those changes. On the plus side, the binding now works with my soundbar and has enabled scalar on my bluray players. Iāve also ordered a AVR (dn1080) to test with (suppose to arrive next week - may or may not be able to test with it before the next release). I think a version might be good to release next week.
Please note that there will be some backward compatibility issues with this (Iām dropping one channel) and I definitely will have some files for you all to send me back.
@andirs
Iām having troubles finding that āstorage doesnāt existā issue. Could you stop your openhab, blow the log away, and restart openhab - wait until it goes offline again with āstorage doesnāt existā - then send me the log? I need to see all the steps itās taking to get there.
Note: instead of posting to the log - could you just put it into send.firefox.com and post the link. That way itās not taking up resourcesā¦
For a short time the thing goes online (which can also be seen in the log) and then i am able to control the TV, but shortly after that it goes offline
Are you running this on a PI by any chance? It looks like the connection attempt is running longer than it should and is being cancelled each time (which may be a result of an slow processor like the PI). Regardless - could you go into the thing configuration and bump the āRetry Pollingā setting up (make it like 60) and see if it goes online.
Yes i am running it on an RPi 3. I guess recources shouldnāt be an issue since there is plenty of CPU and memory recources left. Changing the polling to 60s made that the thing stayed online for approx. 60s and then went offline with the same error. Maybe i should just deactivate the polling
Edit: When deactivating the polling (-1s) it actually seems that the Thing stays online and operable. However i donāt know what could be the negative long term effects.
Furthermore i noticed the (new) behaviour that the tv channel switches remain ON when i switch to a new channel. In the old binding version i can remeber that it was different. I am not sure if a switch immediately went OFF again or if only the last switch remained ON and the others turned OFF. This way several (in an extreme case all) channels could be ON at the same time. Donāt know if this is intended, so thought i report
From working with the NEEO binding - I know PIs have limited capabilities and the sony addon will definitely stress it out at startup because it does a BUNCH of calls/processing to startup (and on each polling). With polling disabled, youāre seeing some of the side effects - if there is a channel that affects other channels, those other channels wonāt change because the polling is disabled (so the other channels wonāt turn to OFF because it doesnāt know itās off). Outside of what you noticed, there will be side effects to volume and a few other things that are ārelatedā.
Just an experiment - Try setting it to some huge value (like 600 for 10 minutes) and see if it comes online (stays online) and your ON/OFF goes away (of course after 10 minutes). Iām betting it will. If it doesnāt - itās something in my code.
Performance will eventually be looked at (like I did with NEEO addon and got it to run reasonably on a PI3) - but itās not very high on the priority right now unfortunatelyā¦
EDIT:
Another interesting thing - you can keep it at -1, look in your log for āAttempting connection to Scalar Web deviceā¦ā and note the timestamp. Then look after that to the āONLINEā debug message to see itās timestamp - that should tell you how long it took to do the initial (and polling) time. Would be interesting to hear what it was (then you can intelligently set the polling to that time plus some extra)
Thanks for your suggestions. Here is what i found out:
I set the āretry pollingā to 600s. During the first 10 minutes i can change channels and the ON/OFF switches issue is not present like when I set i to -1s. When activating a new channel the previous goes off. But after 10 minutes the Thing goes off again:
2019-04-04 17:25:07.888 [hingStatusInfoChangedEvent] - 'sony:scalar:18e7d15c5870' changed from OFFLINE (COMMUNICATION_ERROR): Storage doesn't exist. to ONLINE
2019-04-04 17:35:18.543 [hingStatusInfoChangedEvent] - 'sony:scalar:18e7d15c5870' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Storage doesn't exist.
What i also found out is that my Thing changes over time (i suspect when the port changes in the Scalar Web URL). When it changes all settings are reset. So my access code is āRQSTā again and my retry polling is also the default value again. Observed that behaviour several times now. Donāt know if it is related, but it seems this is (also) a bug.
@andirs
Interesting about the port change - if thatās the case, I see why all the values change back as well (since thatās part of discovery). Let me think on that one
