Me too with scalar… constant binding reqs every second or so.
@tmrobert8 what should this warning mean?
2019-04-28 18:09:45.566 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: sony:dynamic
it appears every now and then, and when it does, it’s repeated for 15-20 times in a row…
to answer my own message… after installing latest version of the binding i did actually found that folder maybe it’s smth specific to OH2.5? As before i was working on OH2.4…
Btw, @tmrobert8 I’ll test the binding a bit tonight, and then i’ll send you all the logs you’re interested in…
Same here
Will try to answer everyone in this single response:
- Yes - if userdata/sony directory doesn’t exist, don’t worry about it - that’s just to clean up any data that may still be there from a prior version
- The flashing RQST on the screen. Confirmed and will be fixed in the next version
- “sony:dynamic” - expected actually. This was a workaround to something openHAB enforces that I don’t use. However, the next version may be able to suppress that message as well. Basically ignore this message for now (and it shouldn’t cause any issues)
Awesome. It will be good to fix the RWST popups so that I can try the scalar version for my TV.
Thanks for your work Tim!
It puzzles me that i’m using scalar and i don’t have these popups?!
The popups will (should?) only appear if you haven’t already paired using scalar. Once you pair - the popups should go away
That’s what i though, but other messages in this thread made my certainty, uncertain
Hi @tmrobert8,
Have just had a quick look at your addon (rel 2.5-04/24-1), looks great , and so far it works with the devices I have tested.
But then I try to access http://localhost:8080/sony/index.html I get 404 “Not Found”, is there anything I have to do to get this to work? I have a new clean install of Openhab2.5 with only your addon nothing else.
I’ll fully admit that I haven’t tried it on 2.5 - so I don’t know if something has changed with their webservices that would make that invalid (I’ll try on a 2.5 system later next week). Just to make sure - you’re running 2.5 locally as well (otherwise local host wouldn’t work), you aren’t using https and you can access paperui on http://localhost:8080?
Basically - it’s the same address as paperui - just /sony/index.html instead of /paperui/index.html…
BTW - you have a DN1080 to test with? Next week - can I send you a definition file that will mimic the groupings (main zone, zone 2, etc) that you did in sony audio?
Thanks,
Tim
for the record, I get the 404 also. I’m running openHAB 2.5.0 Build #1572 and I try to access the page with http://openhabian:8080/sony/index.html
I can access PaperUI on that machine.
To the other testers: Don’t you have the problem that the binding won’t notice changes to the tv station if you do it on the TV?
Using wich protocol? I am using SimpleIP cause Scalar did not work for me so far. With SimpleIP switching the station is recognized by the binding even if I use my TV remote.
Sometimes I think it doesn’t recognize that I have turned the TV on. But can’t reproduce it. I guess it is when the TV starts via CEC HDMI command from an external device.
After changing volume or station the state is updated in Openhab.
Sorry i meant Scalar and was refering to tmrobert’s instructions in post 672
I can confirm this, also having this behaviour. The scalar binding doesn’t get updates from the changes made on the TV itself…
Just to let you know - that I’ve tracked down the ‘nothing changes’ issue on bravia tvs and hopefully the pairing issue as well. I’ll be testing tonight and will put out a new version (if everything works) tomorrow solving those two issues…
You are the man.
i’ll give it a go tomorrow since i am at home this week due to a broken arm
I’m trying to figure this one out as well:
I have an older KDL-46EX720.
After installing the binding, the discovery and adding only the MAC address and Access Code manually, my configuration looks like this:
The device is online but the problem is, it doesn’t do anything. I’m also a bit puzzled about the Access Code entry since my TV doesn’t require one.
Any pointers would be appreciated!
Just an update - the maven build process might be broken and I haven’t been able to generate a build yet. When I get an answer, I’ll post the new release here.
