Hi Guys!
Anybody can help me on how to assigned the correct items, i have managed to create custome items by doing it manually but appart from the power switch nothing else works. please help
Hi Guys!
I seem to have two very minor problems with version [2.5 07/23 1]
Every 10 seconds i see this in the log:
2019-07-28 14:46:19.823 [INFO ] [nding.sony.internal.dial.DialHandler] - Attempting connection to DIAL device...
2019-07-28 14:46:29.839 [INFO ] [nding.sony.internal.dial.DialHandler] - Attempting connection to DIAL device...
2019-07-28 14:46:39.856 [INFO ] [nding.sony.internal.dial.DialHandler] - Attempting connection to DIAL device...
2019-07-28 14:46:49.872 [INFO ] [nding.sony.internal.dial.DialHandler] - Attempting connection to DIAL device...
2019-07-28 14:46:59.888 [INFO ] [nding.sony.internal.dial.DialHandler] - Attempting connection to DIAL device...
2019-07-28 14:47:09.903 [INFO ] [nding.sony.internal.dial.DialHandler] - Attempting connection to DIAL device...
The other thing is, i can turn the TV on and off from openHAB. Instant as expected.
If i turn it on from the remote, it takes about 10 seconds to get the new state into openhab. When turned off, i think it takes another 10 seconds maybe a bit longer.
I used the scalar web device.
Not a real big issue, but just wondering is the scaler web event driven? Or is it polling every x seconds?
Does the binding now support status updates from apps/channels?
I just tried but it seemed the binding didnāt notice me starting and stopping apps on the tvā¦
Itās polling. If you go to the settings in the thing it gives you polling options to have it more/less often or not at all.
Sounds like you donāt have simple linking on.
In paper ui ->menu->configuration->system
Under item linking turn on simple mode.
Delete your thing
Re add your thing
Should auto populate with items
If itās the issue I think your having.
Unfortunately I donāt have any experience with having simple mode off.
Hi I have manged to make it work trough ip simple. so i guess im getting very close.
so now ONLY TWO PROBLEM that i hope you guys can guide me through the right direction:
using res/itmes it sais that is read only. where is that file and how can i make writable so i can add tags??
Question number 2.
if insert in text hdm2 and and ticket the TV responds and switched to HDMI2 and if HDMI4 switches to HDMI4. So what kind of tag can i use so that i can expose this to ALEXA. according to tag control the type is a String
Thanks again everybody, im sure this could help some other people as well on this forum
Trying to get around to everything that people have mentioned:
I think that covers everyone?
Tim
hi tmrobert,
thank you for your answer, after lots of trying i got to the bottom of tagging and this is the aswer. if you ad item automatically they are in read mode hece you wont be able to tag them using the tool, i deleted al the automatic items and added manually and this did the trick after that i was able to tag the items. the only pending task now is what kind of tag and/or label can i use so that i can expose a string to ALEXA. according to tag control the type is a String
Hey Tim,
Nope, you missed me and @markus7017 !
Did you get a chance to respond re the log errors that appear with the 2.4 build from Markus?
Cheers!
Those errors have something to do with the 2.4 conversion and Iām working with @markus7017 on them a bit.
FYI - played with the DIAL protocol a bit and Sony definitely broke the protocol awhile back to prevent the ability to determine what is running and what isnāt (all apps always return āstoppedā regardless if they are started or not). Canāt seem to find a way around it so we may be out of luck. Donāt know if @freke can file a report on this or not (PM if you need more info)
Just an FYI - found some issues in scalar tv channel switching that Iāll be addressing in the next drop
EDIT: also fixed an issue in DIAL application launching that @markus7017 found as well
Hi tmrobert8,
I am getting an error when trying to add the jar you provided:
2019-07-31 17:02:54.758 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/Users/PATH/openhab2/addons/org.openhab.binding.sony-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.sony [267]
Unresolved requirement: Import-Package: com.google.gson; version="[2.8.0,3.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
@Jonas88
Look at the first post - Iāve started posting fixes for stuff like that..
I am sorry. I must have missed that. Did as you said and rebooted.
TV got recognized and iāll report back once i configured it.
Thank you very much for your great work!
Please note that Iāll likely be releasing a new version today with some critical fixes - so stay tuned
will do i am just glad the tv shows up now in this version.
New release: Release 2.5-0731-01: [avmfritz] Added unit tests for templates (#5602) Ā· tmrobert8/openhab-addons Ā· GitHub
Youāll see the notes on the release page
Maybe usefull for developing, but before making a PR, you might want to adres the logging or rate of logging:
2019-08-01 10:27:19.344 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:27:19.536 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:27:29.381 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:27:29.551 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:27:39.416 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:27:39.572 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:27:49.451 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:27:49.590 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:27:59.487 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:27:59.609 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:28:09.524 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:28:09.627 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:28:19.561 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:28:19.646 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:28:29.600 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:28:29.664 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:28:39.635 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:28:39.684 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:28:49.674 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:28:49.700 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:28:59.711 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:28:59.715 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:29:09.733 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:29:09.744 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:29:19.755 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:29:19.773 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:29:29.775 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:29:29.802 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:29:39.797 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:29:39.831 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:29:49.816 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:29:49.861 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:29:59.838 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:29:59.892 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:30:09.860 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:30:09.922 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:30:19.880 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:30:19.953 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:30:29.900 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:30:29.982 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:30:39.919 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:30:40.014 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:30:49.940 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:30:50.045 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:30:59.961 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:31:00.076 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:31:09.984 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:31:10.106 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:31:20.003 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:31:20.138 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:31:30.024 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:31:30.168 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:31:40.063 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:31:40.200 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:31:50.084 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:31:50.234 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:32:00.104 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:32:00.266 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:32:10.123 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:32:10.295 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:32:20.144 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:32:20.325 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:32:30.159 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:32:30.355 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:32:40.181 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:32:40.388 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:32:50.199 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:32:50.421 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
2019-08-01 10:33:00.220 [INFO ] [nding.sony.internal.ircc.IrccHandler] - Attempting connection to IRCC device...
2019-08-01 10:33:00.452 [INFO ] [.internal.scalarweb.ScalarWebHandler] - Attempting connection to Scalar Web device...
And what does this mean?
2019-08-01 11:14:14.831 [INFO ] [rotocols.ScalarWebAppControlProtocol] - Can't get text form - no public key
