Results:
Results:
same here, but i guess that itās due to me not setting up the aerial tv at all
Result:
[[{āsourceā:ātv:dvbcā},{āsourceā:ātv:dvbtā}]]
Thank you all for your responses - FYI this is to restore the ability to quickly choose a preset. There will be new channels called āPS_Channel-xxxā (where xxx is analog, atsct, dvbc, dvbt, etc) that will allow you to send a preset to and the TV will change to it (this also works for radio presets on AVRs). Example: send ā50.1ā to PS_Channel-atsct will switch the TV to channel 50.1 (as long as itās a valid preset).
Note: I have one remaining issue left that I have to tackle before I release this. I should have something by tomorrow I believeā¦
Status update - was hoping for today but it wonāt be. Unfortunately leaving for a long weekend late tomorrow and donāt want to publish and have things blow up while Iām gone so it will likely be next monday instead.
I donāt want to be rude but do you have any plans finishing this?
lol - been the goal for the last two years. After this one - I think the only thing left is to fix whatever bugs come up, address the port issue above and then start the onerous documenting phase (thatās the real reason this hasnāt finished - openHAB just has too onerous of requirements for large bindings like this)
Thanks for all of the work youāve done on this binding. Itās been a huge help to me.
That would be really greatā¦ I am using SimpleIP at the moment only because i canāt (or rather donāt want to) always update the Thing definition
New release!
See https://github.com/tmrobert8/openhab2-addons/releases/tag/2.5-1216-01
Important notes:
Installation:
Changes:
avContent#ps_channel-XXXX
where XXXX is the source (atsct, analog, dvbc, fm, etc) based on what your device says (either TV or Radio for AVRs). This will allow you to select [quickly] a preset channel. Example: I could send ā50.1ā to ps_channel-atsct
to quickly select digital channel 50.1. This ONLY works with channels that have been scanned/preset on the TV/AVR. Note: takes about 30 seconds after the thing to go online for this channel to actually become operational and itās clearly not a fast API call (my TV sometimes took up to about 10 seconds to actually switch).userdata/sony
directory and use that as the source for channels for your device (bypassing the need for the device to be on).Iām a bit nervous abut 2 and 3 but weāll see how it plays out in practice. This slightly mimics how zwave binding does - but we are using github as the ādatabaseā here (in addition to uploading capability information for myself)
Good luck and make sure you backup before doing this - if things go badly, youāll want to restore!
Tim
I have the following behaviour. Every 30s (my Scalar Thing refresh time) my App Items change from Stop to the AppName and back to stop:
2019-12-19 15:36:33.303 [vent.ItemStateChangedEvent] - St_Tv_AppYoutube_Lr changed from stop to YouTube
2019-12-19 15:36:33.347 [vent.ItemStateChangedEvent] - St_Tv_AppYoutube_Lr changed from YouTube to stop
2019-12-19 15:36:33.350 [vent.ItemStateChangedEvent] - St_Tv_AppTED_Lr changed from stop to TED
2019-12-19 15:36:33.352 [vent.ItemStateChangedEvent] - St_Tv_AppTED_Lr changed from TED to stop
2019-12-19 15:36:33.355 [vent.ItemStateChangedEvent] - St_Tv_AppNetflix_Lr changed from stop to Netflix
2019-12-19 15:36:33.357 [vent.ItemStateChangedEvent] - St_Tv_AppNetflix_Lr changed from Netflix to stop
2019-12-19 15:36:33.360 [vent.ItemStateChangedEvent] - St_Tv_AppZDF_Lr changed from stop to ZDFmediathek
2019-12-19 15:36:33.362 [vent.ItemStateChangedEvent] - St_Tv_AppZDF_Lr changed from ZDFmediathek to stop
2019-12-19 15:36:33.365 [vent.ItemStateChangedEvent] - St_Tv_AppARD_Lr changed from stop to ARD Mediathek
2019-12-19 15:36:33.366 [vent.ItemStateChangedEvent] - St_Tv_AppARD_Lr changed from ARD Mediathek to stop
2019-12-19 15:36:33.369 [vent.ItemStateChangedEvent] - St_Tv_AppKodi_Lr changed from stop to Kodi
2019-12-19 15:36:33.371 [vent.ItemStateChangedEvent] - St_Tv_AppKodi_Lr changed from Kodi to stop
2019-12-19 15:36:33.374 [vent.ItemStateChangedEvent] - St_Tv_AppArte_Lr changed from stop to ARTE
2019-12-19 15:36:33.375 [vent.ItemStateChangedEvent] - St_Tv_AppArte_Lr changed from ARTE to stop
Need a debug log file of everything from one change to the next change
Hi guys! I cannot make this binding to work after updating openhab to 2.5.0
IĀ“m trying to configure this binding using files.
IĀ“m using the latest binding file and applied the fixes in the first post.
here is my thing file:
Thing sony:simpleip:home āTVā [ipAddress=ā192.168.100.6ā, commandsMapFile=ābraviaircodes.mapā, netInterface=āeth0ā, ping=30, retryPolling=10 ]
and my item:
Switch TVpower āTV Powerā {channel=āsony:simpleip:home:powerā}
but all I get in the ui is āUNINITIALIZED - HANDLER_CONFIGURATION_PENDINGā
can you point me to the right direction?
Your first attempt should be to see if you can autodiscover it via paperui rather than manually setting it up - then copy the config parameters to your things file.
However given that, your issue is with the configuration (which is using the documentation from 2 years ago that has not been updated and why I suggest the autodiscover route first).
ipAddress
was renamed to deviceAddress
ping
was renamed to checkStatusPolling
personally - Iād simply specify (and let the others default)
Thing sony:simpleip:home āTVā [ipAddress=ā192.168.100.6ā,commandsMapFile=ābraviaircodes.mapā]
I have to say: THANK YOU SIR!!!
modifying the āipAddressā to ādeviceAddressā did the trick!!
I was going crazy with this and stay woke till 3 am trying to find this!!
I could not find the recent documentation on this changes but maybe if someone is having the same problem as me, they can find this here now
again, thanks for your time
Thatās because there is none! Up to now - the binding has been a pretty moving target and documentation has lagged quite a bit. Iām having @andirs test my last change (simplified configuration) and once I release that - Iām going to concentrate on getting this binding merge-able (which includes updating documentation).
[[{āsourceā:ātv:dvbsā},{āsourceā:ātv:dvbtā}]]
Sony KD-55XE9005
I believe I just found this issue and fixed it - will be in the next releaseā¦
New release: https://github.com/tmrobert8/openhab2-addons/releases/tag/2.5-1220-01
Changes:
Note on the āsimplified configurationā. What I mean by that is that on IRCC, DIAL and SCALAR - you can now just specify the IP address rather than the long url that autodiscover finds. This will allow you to manually setup a .things file with simplified configuration (deviceAddress=192.168.1.100
as an example) or to use paperui to manually create a thing directly with just the ip address.
Word of warning however - doing this makes alot of internal assumptions about the device and will probably work with most devices. If your device doesnāt go online, then you probably need to find the autodiscovery URL to set it up correctly because your device varied from the standard setup assumptions.
1K post - woooo!!!
