oppo1967p
(oppo1967p)
January 29, 2017, 3:22pm
101
Hi Tim,
just tested the new binding. For me everything works fine except the following:
volume does not work when using headphone (external speakers) connected to the TV.
when changing channels with the remote, the sitemap is not updated. Need to update manually.
thanks for your work.
Using Bravia 49XD8305.
Tomibeck
(Tomibeck)
January 31, 2017, 2:44pm
102
Hey tim still no luck.
Any advice on troubleshooting?
Thomas
andirs
(Andi)
January 31, 2017, 5:11pm
103
Hello Tim, the new version seems to have solved my old issue, but now produces log flodding when the TV is off:
2017-01-31 18:03:35.784 [INFO ] [y.internal.simpleip.SimpleIpProtocol] - Response took too long - ignoring
2017-01-31 18:04:08.950 [INFO ] [y.internal.simpleip.SimpleIpProtocol] - Response took too long - ignoring
2017-01-31 18:04:42.168 [INFO ] [y.internal.simpleip.SimpleIpProtocol] - Response took too long - ignoring
2017-01-31 18:06:21.702 [INFO ] [y.internal.simpleip.SimpleIpProtocol] - Response took too long - ignoring
2017-01-31 18:06:54.874 [INFO ] [y.internal.simpleip.SimpleIpProtocol] - Response took too long - ignoring
2017-01-31 18:07:28.051 [INFO ] [y.internal.simpleip.SimpleIpProtocol] - Response took too long - ignoring
2017-01-31 18:08:01.225 [INFO ] [y.internal.simpleip.SimpleIpProtocol] - Response took too long - ignoring
Is that related to each other?
tmrobert8
(Tim Roberts)
February 2, 2017, 12:58pm
104
Thomas,
Just to make sure I understand - the old binding did discover the tv and was working? The new binding doesnât discover the tv?
Tim
tmrobert8
(Tim Roberts)
February 2, 2017, 1:03pm
106
Andi,
That shouldnât be happening and Iâll look into it (and have it fixed in the next version).
Tim
Tomibeck
(Tomibeck)
February 2, 2017, 1:09pm
107
Exactly behaviour of the old one:
-TV was autodiscoverd
-Thing went offline immediately
-after adding the correct MAC Thing came back online
New Binding:
-Nothing happens (no auto discovery)
Btw is there a way for me to check if the TV Supports the Webscaler API ? (without the Binding)
Thomas
tmrobert8
(Tim Roberts)
February 2, 2017, 6:46pm
108
Turn on debug logging for the binding. Type âlog:set DEBUG org.openhab.binding.sonyâ in the console. Restart openhab and in the console (after a few minutes) - you should see a line that looks like similar to â>>> GET: http://192.168.1.72:13737/sony/webapi/ssdp/dd.xml
â from the class ââŠsony.internal.net.HttpRequestâ (obvious different IP address - may even be a different url). Following that line there should be a â<<< 200 (<?xml version="1.0"?>
â with a bunch of XML after that (somewhere in the XML - should contain your model #". If you could, copy/paste the whole XML back in a reply.
To answer you question - in the XML there should be a node called âX_ScalarWebAPI_DeviceInfoâ that will give me the information to determine if your set supports the new API. Note: there should also be a âX_IRCC_DeviceInfoâ node that describes the IRCC service as well.
Stuliet
(Stuart Roberts)
February 2, 2017, 10:13pm
109
Quick question, should I be able to control an AV amp with this binding? I have a STR-DN1050 and it is discovered as an IIRC device but is marked offline with the error;
âError connecting to IRCC device (may need to turn it on manually)â
Turning on DEBUG logs I get this output; http://pastebin.com/6tC0A2za There seems to be a problem connecting to a couple of the URLâs but I am not exactly sure what I should be seeing
I did test a script I found here https://www.domoticz.com/forum/viewtopic.php?t=10587 which seems to allow control of the amp OK.
Any ideas on solving this error (hoping there is a solution)?
Thanks,
â Stuart
Tomibeck
(Tomibeck)
February 2, 2017, 10:59pm
110
I only see the binding initializing:
2017-02-02 22:31:06.139 [DEBUG] [org.openhab.binding.sony ] - BundleEvent STARTING - org.openhab.binding.sony
2017-02-02 22:31:06.179 [DEBUG] [org.openhab.binding.sony ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={component.name=org.openhab.binding.sony.discovery.dial, component.id=185, service.id=326, service.bundleid=204, service.scope=bundle} - org.openhab.binding.sony
2017-02-02 22:31:06.199 [DEBUG] [org.openhab.binding.sony ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={component.name=org.openhab.binding.sony.discovery.ircc, component.id=186, service.id=327, service.bundleid=204, service.scope=bundle} - org.openhab.binding.sony
2017-02-02 22:31:06.212 [DEBUG] [org.openhab.binding.sony ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={component.name=org.openhab.binding.sony.discovery.simpleip, component.id=187, service.id=328, service.bundleid=204, service.scope=bundle} - org.openhab.binding.sony
2017-02-02 22:31:06.232 [DEBUG] [org.openhab.binding.sony ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=binding.sony, component.id=188, service.id=329, service.bundleid=204, service.scope=bundle} - org.openhab.binding.sony
2017-02-02 22:31:06.236 [DEBUG] [org.openhab.binding.sony ] - BundleEvent STARTED - org.openhab.binding.sony
Thats it. I also tried tog et the xml via postman request. didnt work
tmrobert8
(Tim Roberts)
February 6, 2017, 1:36pm
111
Stuart,
Glad somebody has an AV to test with! Iâll take a look at your output and get back to you shortlyâŠ
Tim
tmrobert8
(Tim Roberts)
February 6, 2017, 1:37pm
112
Tomibeck,
You will need to trigger the autodiscovery process for the output to appear (if it already appears in the inbox, delete it and manually start the discovery process). Hopefully that will output what I need.
Thanks,
Tim
Tomibeck
(Tomibeck)
February 6, 2017, 4:20pm
113
Hey Tim not working with the up do date version of the bining but with the one before:
<root xmlns="urn:schemas-upnp-org:device-1-0"
xmlns:pnpx="http://schemas.microsoft.com/windows/pnpx/2005/11"
xmlns:df="http://schemas.microsoft.com/windows/2008/09/devicefoundation">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
<friendlyName>BRAVIA KDL-55W905A</friendlyName>
<manufacturer>Sony Corporation</manufacturer>
<manufacturerURL>http://www.sony.net/</manufacturerURL>
<modelName>KDL-55W905A</modelName>
<modelNumber>MINT1.7.0.1</modelNumber>
<UDN>uuid:00000000-0000-1010-8000-3c0771f804b3</UDN>
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMR-1.50</dlna:X_DLNADOC>
<microsoft:magicPacketWakeSupported xmlns:microsoft="urn:schemas-microsoft-com:WMPNSS-1-0">1</microsoft:magicPacketWakeSupported>
<iconList>
<icon>
<mimetype>image/png</mimetype>
<width>32</width>
<height>32</height>
<depth>24</depth>
<url>/MediaRenderer_32x32.png</url>
</icon>
<icon>
<width>48</width>
<height>48</height>
<depth>24</depth>
<url>/MediaRenderer_48x48.png</url>
</icon>
<icon>
<width>60</width>
<height>60</height>
<depth>24</depth>
<url>/MediaRenderer_60x60.png</url>
</icon>
<icon>
<width>120</width>
<height>120</height>
<depth>24</depth>
<url>/MediaRenderer_120x120.png</url>
</icon>
<icon>
<mimetype>image/jpeg</mimetype>
<width>32</width>
<height>32</height>
<depth>24</depth>
<url>/MediaRenderer_32x32.jpg</url>
</icon>
<icon>
<width>48</width>
<height>48</height>
<depth>24</depth>
<url>/MediaRenderer_48x48.jpg</url>
</icon>
<icon>
<width>60</width>
<height>60</height>
<depth>24</depth>
<url>/MediaRenderer_60x60.jpg</url>
</icon>
<icon>
<width>120</width>
<depth>24</depth>
<url>/MediaRenderer_120x120.jpg</url>
</icon>
</iconList>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
<serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
<SCPDURL>/RenderingControlSCPD.xml</SCPDURL>
<controlURL>/upnp/control/RenderingControl</controlURL>
<eventSubURL>/upnp/event/RenderingControl</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
<SCPDURL>/ConnectionManagerSCPD.xml</SCPDURL>
<controlURL>/upnp/control/ConnectionManager</controlURL>
<eventSubURL>/upnp/event/ConnectionManager</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
<serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
<SCPDURL>/AVTransportSCPD.xml</SCPDURL>
<controlURL>/upnp/control/AVTransport</controlURL>
<eventSubURL>/upnp/event/AVTransport</eventSubURL>
</service>
<service>
<serviceType>urn:dial-multiscreen-org:service:dial:1</serviceType>
<serviceId>urn:dial-multiscreen-org:serviceId:dial</serviceId>
<SCPDURL>/DIALSCPD.xml</SCPDURL>
<controlURL>/upnp/control/DIAL</controlURL>
<eventSubURL></eventSubURL>
</service>
<service>
<serviceType>urn:schemas-sony-com:service:IRCC:1</serviceType>
<serviceId>urn:schemas-sony-com:serviceId:IRCC</serviceId>
<SCPDURL>/IRCCSCPD.xml</SCPDURL>
<controlURL>http://192.100.20.6/sony/IRCC</controlURL>
</service>
<service>
<serviceType>urn:schemas-sony-com:service:ScalarWebAPI:1</serviceType>
<serviceId>urn:schemas-sony-com:serviceId:ScalarWebAPI</serviceId>
<SCPDURL>/ScalarWebApiSCPD.xml</SCPDURL>
<controlURL>/upnp/control/ScalarAPI</controlURL>
</service>
</serviceList>
<av:X_MaxBGMCount xmlns:av="urn:schemas-sony-com:av">64</av:X_MaxBGMCount>
<av:X_StandardDMR xmlns:av="urn:schemas-sony-com:av">1.1</av:X_StandardDMR>
<av:X_ScreenResolution xmlns:av="urn:schemas-sony-com:av">2K</av:X_ScreenResolution>
<av:X_IRCCCodeList xmlns:av="urn:schemas-sony-com:av">
<av:X_IRCCCode command="Power">AAAAAQAAAAEAAAAVAw==</av:X_IRCCCode>
<av:X_IRCCCode command="Power ON">AAAAAQAAAAEAAAAuAw==</av:X_IRCCCode>
<av:X_IRCCCode command="Power OFF">AAAAAQAAAAEAAAAvAw==</av:X_IRCCCode>
</av:X_IRCCCodeList>
<pnpx:X_compatibleId>MS_DigitalMediaDeviceClass_DMR_V001</pnpx:X_compatibleId>
<pnpx:X_deviceCategory>MediaDevices</pnpx:X_deviceCategory>
<pnpx:X_hardwareId>VEN_0106&DEV_0006&REV_01</pnpx:X_hardwareId>
<df:X_deviceCategory>Display.TV Multimedia.DMR</df:X_deviceCategory>
<av:X_TrackID_DeviceInfo xmlns:av="urn:schemas-sony-com:av">
<av:X_TrackID_BaseURL>http://192.100.20.6/sony/BgmSearch</av:X_TrackID_BaseURL>
</av:X_TrackID_DeviceInfo>
<av:X_ScalarWebAPI_DeviceInfo xmlns:av="urn:schemas-sony-com:av">
<av:X_ScalarWebAPI_Version>1.0</av:X_ScalarWebAPI_Version>
<av:X_ScalarWebAPI_BaseURL>http://192.100.20.6/sony</av:X_ScalarWebAPI_BaseURL>
<av:X_ScalarWebAPI_ServiceList>
<av:X_ScalarWebAPI_ServiceType>guide</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>system</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>videoScreen</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>audio</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>avContent</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>recording</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>appControl</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>browser</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>notification</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>cec</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>accessControl</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>irCommandProxy</av:X_ScalarWebAPI_ServiceType>
</av:X_ScalarWebAPI_ServiceList>
</av:X_ScalarWebAPI_DeviceInfo>
<av:X_RDIS_DeviceInfo xmlns:av="urn:schemas-sony-com:av">
<av:X_RDIS_Version>1.0</av:X_RDIS_Version>
<av:X_RDIS_SESSION_CONTROL>false</av:X_RDIS_SESSION_CONTROL>
<av:X_RDIS_ENTRY_PORT>20677</av:X_RDIS_ENTRY_PORT>
</av:X_RDIS_DeviceInfo>
<av:X_DIALEX_DeviceInfo xmlns:av="urn:schemas-sony-com:av">
<av:X_DIALEX_AppsListURL>http://192.100.20.6/DIAL/sony/applist</av:X_DIALEX_AppsListURL>
</av:X_DIALEX_DeviceInfo>
</device>
</root>
2017-02-06 16:10:06.852 [DEBUG] [inding.sony.internal.net.HttpRequest] - >>> GET: http://192.100.20.6:52323/ScalarWebApiSCPD.xml
2017-02-06 16:10:06.853 [DEBUG] [inding.sony.internal.net.HttpRequest] - <<< 200 (<?xml version="1.0"?>
<scpd xmlns="urn:schemas-upnp-org:service-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<serviceStateTable>
<stateVariable sendEvents="no">
<name>X_ScalarWebAPI</name>
<dataType>string</dataType>
</stateVariable>
</serviceStateTable>
</scpd>
2017-02-06 16:10:06.874 [DEBUG] [inding.sony.internal.net.HttpRequest] - >>> GET: http://192.100.20.6:52323/IRCCSCPD.xml
2017-02-06 16:10:06.875 [DEBUG] [inding.sony.internal.net.HttpRequest] - <<< 200 (<?xml version="1.0"?>
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<actionList>
<action>
<name>X_SendIRCC</name>
<argumentList>
<argument>
<name>IRCCCode</name>
<direction>in</direction>
<relatedStateVariable>X_A_ARG_TYPE_IRCCCode</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>X_GetStatus</name>
<argumentList>
<argument>
<name>CategoryCode</name>
<relatedStateVariable>X_A_ARG_TYPE_Category</relatedStateVariable>
</argument>
<argument>
<name>CurrentStatus</name>
<direction>out</direction>
<relatedStateVariable>X_A_ARG_TYPE_CurrentStatus</relatedStateVariable>
</argument>
<argument>
<name>CurrentCommandInfo</name>
<relatedStateVariable>X_A_ARG_TYPE_CurrentCommandInfo</relatedStateVariable>
</argument>
</argumentList>
</action>
</actionList>
<serviceStateTable>
<name>X_A_ARG_TYPE_IRCCCode</name>
</stateVariable>
<name>X_A_ARG_TYPE_Category</name>
</stateVariable>
<name>X_A_ARG_TYPE_CurrentStatus</name>
</stateVariable>
<name>X_A_ARG_TYPE_CurrentCommandInfo</name>
</stateVariable>
</scpd>
2017-02-06 16:10:06.915 [DEBUG] [inding.sony.internal.net.HttpRequest] - >>> GET: http://192.100.20.6:52323/DIALSCPD.xml
2017-02-06 16:10:06.917 [DEBUG] [inding.sony.internal.net.HttpRequest] - <<< 200 (<?xml version="1.0" ?>
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<serviceStateTable>
<name>X_DialNullVariable</name>
</stateVariable>
</scpd>
2017-02-06 16:10:06.944 [DEBUG] [inding.sony.internal.net.HttpRequest] - >>> GET: http://192.100.20.6:52323/AVTransportSCPD.xml
2017-02-06 16:10:06.946 [DEBUG] [inding.sony.internal.net.HttpRequest] - <<< 200 (<?xml version="1.0"?>
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<actionList>
<action>
<name>SetAVTransportURI</name>
<argumentList>
<argument>
<name>InstanceID</name>
<relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable>
</argument>
<argument>
<name>CurrentURI</name>
<relatedStateVariable>AVTransportURI</relatedStateVariable>
</argument>
<argument>
<name>CurrentURIMetaData</name>
<relatedStateVariable>AVTransportURIMetaData</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>SetNextAVTransportURI</name>
<argumentList>
<argument>
</argument>
<argument>
<name>NextURI</name>
<relatedStateVariable>NextAVTransportURI</relatedStateVariable>
</argument>
<argument>
<name>NextURIMetaData</name>
<relatedStateVariable>NextAVTransportURIMetaData</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetMediaInfo</name>
<argumentList>
<argument>
</argument>
<argument>
<name>NrTracks</name>
<relatedStateVariable>NumberOfTracks</relatedStateVariable>
</argument>
<argument>
<name>MediaDuration</name>
<relatedStateVariable>CurrentMediaDuration</relatedStateVariable>
</argument>
<argument>
</argument>
<argument>
</argument>
<argument>
</argument>
<argument>
</argument>
<argument>
<name>PlayMedium</name>
<relatedStateVariable>PlaybackStorageMedium</relatedStateVariable>
</argument>
<argument>
<name>RecordMedium</name>
<relatedStateVariable>RecordStorageMedium</relatedStateVariable>
</argument>
<argument>
<name>WriteStatus</name>
<relatedStateVariable>RecordMediumWriteStatus</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetTransportInfo</name>
<argumentList>
<argument>
</argument>
<argument>
<name>CurrentTransportState</name>
<relatedStateVariable>TransportState</relatedStateVariable>
</argument>
<argument>
<name>CurrentTransportStatus</name>
<relatedStateVariable>TransportStatus</relatedStateVariable>
</argument>
<argument>
<name>CurrentSpeed</name>
<relatedStateVariable>TransportPlaySpeed</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetPositionInfo</name>
<argumentList>
<argument>
</argument>
<argument>
<name>Track</name>
<relatedStateVariable>CurrentTrack</relatedStateVariable>
</argument>
<argument>
<name>TrackDuration</name>
<relatedStateVariable>CurrentTrackDuration</relatedStateVariable>
</argument>
<argument>
<name>TrackMetaData</name>
<relatedStateVariable>CurrentTrackMetaData</relatedStateVariable>
</argument>
<argument>
<name>TrackURI</name>
<relatedStateVariable>CurrentTrackURI</relatedStateVariable>
</argument>
<argument>
<name>RelTime</name>
<relatedStateVariable>RelativeTimePosition</relatedStateVariable>
</argument>
<argument>
<name>AbsTime</name>
<relatedStateVariable>AbsoluteTimePosition</relatedStateVariable>
</argument>
<argument>
<name>RelCount</name>
<relatedStateVariable>RelativeCounterPosition</relatedStateVariable>
</argument>
<argument>
<name>AbsCount</name>
<relatedStateVariable>AbsoluteCounterPosition</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetDeviceCapabilities</name>
<argumentList>
<argument>
</argument>
<argument>
<name>PlayMedia</name>
<relatedStateVariable>PossiblePlaybackStorageMedia</relatedStateVariable>
</argument>
<argument>
<name>RecMedia</name>
<relatedStateVariable>PossibleRecordStorageMedia</relatedStateVariable>
</argument>
<argument>
<name>RecQualityModes</name>
<relatedStateVariable>PossibleRecordQualityModes</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetTransportSettings</name>
<argumentList>
<argument>
</argument>
<argument>
<name>PlayMode</name>
<relatedStateVariable>CurrentPlayMode</relatedStateVariable>
</argument>
<argument>
<name>RecQualityMode</name>
<relatedStateVariable>CurrentRecordQualityMode</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>Stop</name>
<argumentList>
<argument>
</argument>
</argumentList>
</action>
<action>
<name>Play</name>
<argumentList>
<argument>
</argument>
<argument>
<name>Speed</name>
</argument>
</argumentList>
</action>
<action>
<name>Pause</name>
<argumentList>
<argument>
</argument>
</argumentList>
</action>
<action>
<name>Seek</name>
<argumentList>
<argument>
</argument>
<argument>
<name>Unit</name>
<relatedStateVariable>A_ARG_TYPE_SeekMode</relatedStateVariable>
</argument>
<argument>
<name>Target</name>
<relatedStateVariable>A_ARG_TYPE_SeekTarget</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>Next</name>
<argumentList>
<argument>
</argument>
</argumentList>
</action>
<action>
<name>Previous</name>
<argumentList>
<argument>
</argument>
</argumentList>
</action>
<action>
<name>GetCurrentTransportActions</name>
<argumentList>
<argument>
</argument>
<argument>
<name>Actions</name>
<relatedStateVariable>CurrentTransportActions</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>X_DLNA_GetBytePositionInfo</name>
<argumentList>
<argument>
</argument>
<argument>
<name>TrackSize</name>
<relatedStateVariable>X_DLNA_CurrentTrackSize</relatedStateVariable>
</argument>
<argument>
<name>RelByte</name>
<relatedStateVariable>X_DLNA_RelativeBytePosition</relatedStateVariable>
</argument>
<argument>
<name>AbsByte</name>
<relatedStateVariable>X_DLNA_AbsoluteBytePosition</relatedStateVariable>
</argument>
</argumentList>
</action>
</actionList>
<serviceStateTable>
<name>TransportState</name>
<allowedValueList>
<allowedValue>NO_MEDIA_PRESENT</allowedValue>
<allowedValue>STOPPED</allowedValue>
<allowedValue>TRANSITIONING</allowedValue>
<allowedValue>PLAYING</allowedValue>
<allowedValue>PAUSED_PLAYBACK</allowedValue>
</allowedValueList>
</stateVariable>
<name>TransportStatus</name>
<allowedValueList>
<allowedValue>OK</allowedValue>
<allowedValue>ERROR_OCCURRED</allowedValue>
</allowedValueList>
</stateVariable>
<name>PlaybackStorageMedium</name>
<allowedValueList>
<allowedValue>NONE</allowedValue>
<allowedValue>NETWORK</allowedValue>
<allowedValue>USB</allowedValue>
</allowedValueList>
</stateVariable>
<name>RecordStorageMedium</name>
<allowedValueList>
<allowedValue>NOT_IMPLEMENTED</allowedValue>
</allowedValueList>
</stateVariable>
<name>PossiblePlaybackStorageMedia</name>
</stateVariable>
<name>PossibleRecordStorageMedia</name>
</stateVariable>
<name>CurrentPlayMode</name>
<allowedValueList>
<allowedValue>NORMAL</allowedValue>
</allowedValueList>
<defaultValue>NORMAL</defaultValue>
</stateVariable>
<name>TransportPlaySpeed</name>
<allowedValueList>
<allowedValue>1</allowedValue>
<allowedValue>10</allowedValue>
<allowedValue>30</allowedValue>
<allowedValue>120</allowedValue>
<allowedValue>-10</allowedValue>
<allowedValue>-30</allowedValue>
<allowedValue>-120</allowedValue>
</allowedValueList>
<defaultValue>1</defaultValue>
</stateVariable>
<name>RecordMediumWriteStatus</name>
<allowedValueList>
</allowedValueList>
</stateVariable>
<name>CurrentRecordQualityMode</name>
<allowedValueList>
</allowedValueList>
</stateVariable>
<name>PossibleRecordQualityModes</name>
</stateVariable>
<name>NumberOfTracks</name>
<dataType>ui4</dataType>
<allowedValueRange>
<minimum>0</minimum>
<maximum>1</maximum>
</allowedValueRange>
</stateVariable>
<name>CurrentTrack</name>
<allowedValueRange>
<step>1</step>
</stateVariable>
<name>CurrentTrackDuration</name>
</stateVariable>
<name>CurrentMediaDuration</name>
</stateVariable>
<name>CurrentTrackMetaData</name>
</stateVariable>
<name>CurrentTrackURI</name>
</stateVariable>
<name>AVTransportURI</name>
</stateVariable>
<name>AVTransportURIMetaData</name>
</stateVariable>
<name>NextAVTransportURI</name>
</stateVariable>
<name>NextAVTransportURIMetaData</name>
</stateVariable>
<name>RelativeTimePosition</name>
</stateVariable>
<name>AbsoluteTimePosition</name>
</stateVariable>
<name>RelativeCounterPosition</name>
<dataType>i4</dataType>
</stateVariable>
<name>AbsoluteCounterPosition</name>
</stateVariable>
<name>CurrentTransportActions</name>
</stateVariable>
<name>X_DLNA_RelativeBytePosition</name>
</stateVariable>
<name>X_DLNA_AbsoluteBytePosition</name>
</stateVariable>
<name>X_DLNA_CurrentTrackSize</name>
</stateVariable>
<stateVariable sendEvents="yes">
<name>LastChange</name>
</stateVariable>
<name>A_ARG_TYPE_SeekMode</name>
<allowedValueList>
<allowedValue>TRACK_NR</allowedValue>
<allowedValue>ABS_TIME</allowedValue>
<allowedValue>REL_TIME</allowedValue>
<allowedValue>ABS_COUNT</allowedValue>
<allowedValue>REL_COUNT</allowedValue>
<allowedValue>X_DLNA_ABS_BYTE</allowedValue>
<allowedValue>X_DLNA_REL_BYTE</allowedValue>
</allowedValueList>
</stateVariable>
<name>A_ARG_TYPE_SeekTarget</name>
</stateVariable>
<name>A_ARG_TYPE_InstanceID</name>
</stateVariable>
</scpd>
2017-02-06 16:10:07.021 [DEBUG] [inding.sony.internal.net.HttpRequest] - >>> GET: http://192.100.20.6:52323/ConnectionManagerSCPD.xml
2017-02-06 16:10:07.022 [DEBUG] [inding.sony.internal.net.HttpRequest] - <<< 200 (<?xml version="1.0"?>
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<actionList>
<action>
<name>GetProtocolInfo</name>
<argumentList>
<argument>
<name>Source</name>
<relatedStateVariable>SourceProtocolInfo</relatedStateVariable>
</argument>
<argument>
<name>Sink</name>
<relatedStateVariable>SinkProtocolInfo</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetCurrentConnectionIDs</name>
<argumentList>
<argument>
<name>ConnectionIDs</name>
<relatedStateVariable>CurrentConnectionIDs</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetCurrentConnectionInfo</name>
<argumentList>
<argument>
<name>ConnectionID</name>
<relatedStateVariable>A_ARG_TYPE_ConnectionID</relatedStateVariable>
</argument>
<argument>
<name>RcsID</name>
<relatedStateVariable>A_ARG_TYPE_RcsID</relatedStateVariable>
</argument>
<argument>
<name>AVTransportID</name>
<relatedStateVariable>A_ARG_TYPE_AVTransportID</relatedStateVariable>
</argument>
<argument>
<name>ProtocolInfo</name>
<relatedStateVariable>A_ARG_TYPE_ProtocolInfo</relatedStateVariable>
</argument>
<argument>
<name>PeerConnectionManager</name>
<relatedStateVariable>A_ARG_TYPE_ConnectionManager</relatedStateVariable>
</argument>
tmrobert8
(Tim Roberts)
February 6, 2017, 5:18pm
114
Good news and bad news. Youâre IRCC service wonât work (like my tv, a recent firmware took away the IRCC action list) - so IRCC wonât work (atleast for now). Good news is that yourâs definately supports ScalarWeb - in fact, it even has a few services that my TV doesnât. Youâll need to wait until Iâve finished that API to try it out. On a side note, can you turn on your TV, then on a PC/laptop/whatever browse to âhttp://192.100.20.6/DIAL/sony/applist â and see if you get anything (probably a access denied - but just a curiosity).
Note: Iâm probably about 25-30% done with the scalarweb right now (I have it connecting, able to request/enter pins, and get information about the tv). Iâm still trying to figure out how to organize the channels however (alot of the scalar api is dynamic).
tmrobert8
(Tim Roberts)
February 6, 2017, 5:30pm
115
Stuart,
Have you paired the binding with the STR-DN1050 yet? Looking at the logs that you posted - doesnât appear to be paired yet. Turn the receiver on (and have it outputting to some display). Edit the configuration of the thing and changes the accessCode to âRQSTâ (probably already says âRQSTâ - just continue then). When you save it - the binding will go into a pairing mode and a 4 digit number should be displayed on the receiverâs display output. Edit the configuration and enter the 4 digit number and save - the binding should then pair with the receiver and go online (note: you only have 45 or 60 seconds to pair - the AV will cancel it after that and youâll need to go through the process again). The important part is the receiver must be on and outputting to a display to do this correctly.
Tomibeck
(Tomibeck)
February 6, 2017, 6:05pm
116
Sound good to me. I rather wait a bit longer and have the new API then. If you need help testing let me know.
The only thing Iâm still curious about is why this is not working at all wir the newer version.
tmrobert8
(Tim Roberts)
February 6, 2017, 6:10pm
117
Old version was giving you a false impression. Didnât have as much detection built into it - so it assumed IRCC was available (since the IRCC node was in that XML) and falsely went online (bet the old version then had issues with issue commands). New version actually investigates the IRCC service to see what it has and wonât discover the device (nor go online) unless certain requirements are met.
Oliverk
(Oliver)
February 6, 2017, 6:36pm
118
Hey Tim, i have a STR-DN1030 AV amp and try to get it up and running with your binding.
when deploying org.openhab.binding.sony-2.1.0-SNAPSHOT.jar from your latest zip the discovery process (initiated by adding a new Thing âSony Bindingâ is not detecting my AV amp on the network, although the binding seems to be deployed correctly:
2017-02-06 17:21:32.196 [DEBUG] [org.openhab.binding.sony ] - BundleEvent STARTING - org.openhab.binding.sony
2017-02-06 17:21:32.216 [DEBUG] [org.openhab.binding.sony ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={component.name=org.openhab.binding.sony.discovery.dial, component.id=180, service.id=307, service.bundleid=191, service.scope=bundle} - org.openhab.binding.sony
2017-02-06 17:21:32.236 [DEBUG] [org.openhab.binding.sony ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={component.name=org.openhab.binding.sony.discovery.ircc, component.id=181, service.id=308, service.bundleid=191, service.scope=bundle} - org.openhab.binding.sony
2017-02-06 17:21:32.245 [DEBUG] [org.openhab.binding.sony ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={component.name=org.openhab.binding.sony.discovery.simpleip, component.id=182, service.id=309, service.bundleid=191, service.scope=bundle} - org.openhab.binding.sony
2017-02-06 17:21:32.257 [DEBUG] [org.openhab.binding.sony ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=binding.sony, component.id=183, service.id=310, service.bundleid=191, service.scope=bundle} - org.openhab.binding.sony
2017-02-06 17:21:32.260 [DEBUG] [org.openhab.binding.sony ] - BundleEvent STARTED - org.openhab.binding.sony
However, when deploying your previous version from Dec 30th org.openhab.binding.sony-2.0.0-SNAPSHOT.jar
my AV amp gets discovered but never gets online.
http://pastebin.com/nyikQp9s
i was not able to pair/authenticate the device yet. Although the discovery process has configured âRQSTâ as access code, my AV amp does not display any code on the screen - even though iâm in GUI Mode. Not sure if itâs neccessary to use the âSettings/Network/Media Remote Deviceâ option on the Sony to register a new media remote, so i tried this option too without success.
any ideas how to include my STR-DN1030 with your binding?
Thanks, Oliver
tmrobert8
(Tim Roberts)
February 6, 2017, 8:35pm
119
Oliver,
The old binding will falsely go online and will never pair because of that - please ignore it completely. Iâm assuming the posted debug log file is from the old binding? The big question is why is the new binding not finding the IRCC service on AVs (same as Stuarts issue). Looking at the debug log - seems like it should be identifying it correctly. Iâm going to be uploading a new version shortly that will add a bunch more debugging information to the autodiscovery process to hopefully tell me whatâs going wrongâŠ
Thanks,
Tim
tmrobert8
(Tim Roberts)
February 6, 2017, 8:46pm
120
Oliver/Stuart,
I just posted a new zip file over on openhab2-addons sony thread (on page 3 now). Give install this and rediscover with debug level on (and post that if you would). This binding will NOT change anything from your perspective but will dump some additional debugging information so I can see (hopefully) what is going on with the AVsâŠ
Thanks,
Tim
