after clean uninstall of the previous version, i have installed the new binding and it seems that there is already some error registering the discovery.ircc component.
2017-02-07 08:38:02.237 [ERROR] [org.openhab.binding.sony ] - [org.openhab.binding.sony.discovery.ircc] Cannot register Component
org.osgi.service.component.ComponentException: The component name 'org.openhab.binding.sony.discovery.ircc' has already been registered by Bundle 196 (org.openhab.binding.sony) as Component of Class org.openhab.binding.sony.discovery.IrccDiscoveryParticipant
Ack - sorry about that - youâre also getting my half scalar implementation that is not even close to testing (and thatâs what caused that). Download the latest (sony-binding-2017-02-07.zip) from that thread - should fix that issue
seems slightly better now, but still error âException getting device infoâ in âIrccDiscoveryParticipantâ⊠and discovery will not find my AV amp.
Discovery shouldnât work yet - Iâm trying to isolate the problem and that exception message is telling me that I was having issues getting the local MAC address. By any chance do you have multiple network cards?
Those duplicate XML will be fix but arenât the root of the issue. The issue is that bad protocol return at the bottom of it. Iâm going to replace jetty and see if that has any effect. Iâll let you know when I have that posted.
You arenât using the test binding are you (and have discovered a scalar api device)? That seems to be a message my, not even half done, scalar service creates. If you are using it and discoverying the scalar service - donât. The binding is not even to the point itâs usable on my system. The latest test binding is trying to get IRCC working on an sony AV system.
If you discovered an IRCC device and are getting that message - please let me know (Iâll need to look at that). BTW - what device are you using (model?)
Iâm assuming you autodiscovered the thing right? If so, go into the paperui->configuration->things - look for your bravia and right under it youâll see some text (âSony IRCCâ or âSony Scalarâ or âSony Dialâ or âSony SimpleIPâ. What does it say?
