Hi!
I want to uise the SonyProjector Binding. I see the “powerstate” channel wich correctly states the current power of my projector. But I want to switch on the projector. And the channel “power” ist missing. Whar am I doing wrong?
Regards…
Hi!
Regards…
This channel is present on all thing types of this binding.
Maybe you are upgrading from an old OH version and your thing was setup with UI. In that case, try to remove your thing and add it again.
Yes - you’re right… thanks! After removing everything and installing again it is available again.
Christoph
This was mentioned in OH 3.2 releasr notes:
