I am looking at integrating the Australian made SPANET SPALINK spa pool controller into my home automation.
The manufacturer says there is no published API available.
Has anyone perhaps deciphered the control message protocol for SPANET, or knows what type of comms are used between their wifi app and the spa controller?
Iāve just got one of these controllers myself (SV2) but it didnāt come with the WiFi module.
I am interested also to integrate the spa into the overall house automation, so Iām going to get myself a module and see what we can do ā¦ have you had any luck yourself with the comms ?
For anyone that makes it here, the only way I have found to automate my Spanet controller is through a Google Assistant Relay. Basically all your normal automation goodness with the action to tell a command to Google to control your spa.
I take it nobody much smarter then me has played with SPANET to figure out what can be done? I think there might be an input on the controller to inhibit heating which I might use as a fallback but would love all the features of the app dragged into openhab.
I realise that I am digging up an old thread, but I just had my spa installed and it comes with a SpaLink.
Iāve done some initial investigation into the comms the iPhone app is using to communicate with SpaNet.
Iāve started a file over on GitHub with the details which I will keep up to date as I work out more.
I should mention that SpaNet makes use of WebSockets. Iāve been able to observe the connected WebSocket via the iPhone app, but I have been so far unsuccessful in creating my own WebSocket.
David - good start! I also have a SpaNet controller. I am hoping I can get to the point that I can change the spa mode to Away remotely. I have another hard wired way to do this however that is going to be a last resort. Let me know how I can help although I am more electrical engineer then software programmerā¦
Iāve been successful in communicating with SpaNet.
I should have made it clear when I first posted. Iām a Home Assistant user, not openHAB.
I previously use Homebridge for development, so I have taken when I have learnt from poking at the SpaNet API and have built a SpaNet homebridge plugin.
Itās mostly working but I want to let it run for a little bit before I release any code.
Hereās a screenshot of it running in Appleās Home app.
That UI looks significantly better than the SpaNet app from the Google Play Store, which presumably is very similar to the iPhone App too.
I am more of a HomeAssistant user, and would be keen to contribute (if I can) to any work that progresses integration of SpaNet there, or in OpenHAB is more applicable.
My ultimate aim would be to be able to ātellā my spa pool that, given an excess of solar-generated power, you might as well heat (or clean, etc.) as the power is effectively free, and not being used by anything else. Plus, have a funky way of control the spa from my phone
Many thanks everyone involved, how great to see there IS a way to communicate with spanet other than the spanet app itself! Fabulous!
Forgive me, I am not familiar with Homebridge or Openhab, but would like to embed the spanet control commands in VBA code.
Is that possible at all?
If yes, where would I find the various commands in the homebridge plugin that spanet responds to, and the spanet responses?
Hi @shanekuz. I know itās almost 2 years ago but Iām keen to know a bit more about how you figured out the protocol of the touchpad. Iāve made a test setup using a USB RS232(TTL) chip and receiving data, however it is not ASCII as what you seem to receive judging by your code on GitHub. Iāve tried different baudrates but cannot identify any patterns in the data received (the SPANet module seems to send unsolicited data)
How did you find out to send āRF:ā (which i have not tried yet). Did you snoop a connected WiFi module?
Oh. and what model SPANet did you use? I have a Spanet SV2 and SV2-T Touchpad
