My Openhab System is working. Also a InfluxDB/Grafana installation is working well. I get nice graphs for my heating actors. So far so good. I like to have also statistic data from the speedtest. But no data are comming to the influxdb database.
my item look like this:
Group gSpeedtest (Whg)
String SpeedtestSummary "Speedtest [%s]" <"speedtest_network"> (gSpeedtest)
Number SpeedtestResultPing "Ping [%.3f ms]" <"speedtest_next5"> (gSpeedtest,gSpeedtestGraph)
Number SpeedtestResultDown "Downlink [%.2f Mbit/s]" <"speedtest_download"> (gSpeedtest,gSpeedtestGraph)
Number SpeedtestResultUp "Uplink [%.2f Mbit/s]" <"speedtest_upload"> (gSpeedtest,gSpeedtestGraph)
String SpeedtestRunning "Speedtest running ... [%s]" <"speedtest_new"> (gSpeedtest)
Switch SpeedtestRerun "Start manually" <"speedtest_reload2"> (gSpeedtest)
DateTime SpeedtestResultDate "Last executed [%1$td.%1$tm.%1$tY, %1$tH:%1$tM Uhr]" <"speedtest_problem4"> (gSpeedtest)
the persitance file look like that:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
Items {
Temps* : strategy = everyChange, everyMinute, restoreOnStartup
gSpeedtestGraph* : strategy = everyChange, everyHour, everyMinute, restoreOnStartup
gSpeedtest* : strategy = everyChange, everyHour, everyMinute, restoreOnStartup
This is my sitemap part:
Frame label="Speedtest" {
Text item=SpeedtestSummary {
Frame label="Ergebnisse" {
Text item=SpeedtestResultDown
Text item=SpeedtestResultUp
Text item=SpeedtestResultPing
Frame label="Steuerung" {
Text item=SpeedtestResultDate
Text item=SpeedtestRunning label="Speedtest [%s]" visibility=[SpeedtestRunning != "-"]
Switch item=SpeedtestRerun mappings=[ON="Start"]
Frame label="Statistik" {
Text label="speedtest" icon="speedtest_analytics8"
and at least the speedtest rule data:
val String filename = "speedtest.rules"
rule "Speedtest init"
System started
createTimer(now.plusSeconds(195)) [|
if (SpeedtestRerun.state == NULL) SpeedtestRerun.postUpdate(OFF)
if (SpeedtestRunning.state == NULL) SpeedtestRunning.postUpdate("-")
if (SpeedtestSummary.state == NULL || SpeedtestSummary.state == "") SpeedtestSummary.postUpdate("(unbekannt)")
rule "Speedtest"
//Time cron "0 0 5 * * ?" or
//Time cron "0 0 13 * * ?"
Time cron "0 0 0 ? * * *" or
Item SpeedtestRerun received command ON
//logInfo(filename, "--> speedtest executed...")
SpeedtestRunning.postUpdate("Messung laeuft...")
// update timestamp for last execution
SpeedtestResultDate.postUpdate(new DateTimeType())
// execute the script, you may have to change the path depending on your system
var String speedtestCliOutput = executeCommandLine("/usr/local/bin/speedtest-cli@@--simple", 120*1000)
// for debugging:
//logInfo(filename, "--> speedtest output:\n" + speedtestCliOutput + "\n\n")
SpeedtestRunning.postUpdate("Datenauswertung...")
// starts off with a fairly simple error check, should be enough to catch all problems I can think of
if (speedtestCliOutput.startsWith("Ping") && speedtestCliOutput.endsWith("Mbit/s")) {
var String[] results = speedtestCliOutput.split("\\r?\\n")
var float ping = new java.lang.Float(results.get(0).split(" ").get(1))
var float down = new java.lang.Float(results.get(1).split(" ").get(1))
var float up = new java.lang.Float(results.get(2).split(" ").get(1))
SpeedtestResultPing.postUpdate(ping)
SpeedtestResultDown.postUpdate(down)
SpeedtestResultUp.postUpdate(up)
SpeedtestSummary.postUpdate(String::format("Down %.1f Mbs Up %.1f Mbs (Ping %.0f ms)", down, up, ping))
//logInfo(filename, "--> speedtest finished.")
} else {
SpeedtestResultPing.postUpdate(0)
SpeedtestResultDown.postUpdate(0)
SpeedtestResultUp.postUpdate(0)
SpeedtestRunning.postUpdate("Fehler bei der Ausfuehrung")
logError(filename, "--> speedtest failed. Output:\n" + speedtestCliOutput + "\n\n")
In the influxdb is no data for the speedtest. Whats wrong?
Bfo
