"Spoken Feedback" selection shows no items
I’m playing a little bit with HABpanel. Unfortunately the selection (“Speak the new value of the following item when it changes:”) shows no values, only an empty one.
I’m using
  • openHAB 2.0.0.201701011144
  • HABPanel User Interface 2.0.0.201701021217
  • on a Raspberry Pi 3 without item files.
Is this a general error/problem or something specific?
On my setup the items are shown, the difference is I use an item file. (I’m on openHAB 2.0.0~20161227112533 (Build #677))
Thank you for your answer.
I added some items (without binding) via items file. Unfortunately I don’t get any items in the selection list. Even the browser can’t be the problem. I tested Chrome (54.0.2840.99 m (64-bit)), Firefox (50.0.2), IE (11.0.14393.0) and Edge. All the same: I don’t get any item.
Anybody any idea?
I lose some items some times… but when i lose them it does not apear in the rest API interface (openhab2) When this hapen i have to restart openhab
Unfortunately all items are returned by the REST API. RPI restart didn’t changed anything, I don’t get any items in the selection list. :frowning:
More ideas?
Found the reason. Only items of type String defined in an items file are provided in my selection list.
@opus and @Dominic_Bonneau can you confirm that?
Confirmed!
Confirmed
@ysc can you say something about the mentioned feature and if this is a bug or not?
That’s right, only String items are displayed and can be used.
Define it in a .items file, and use an openHAB rule to set it and then clear it immediately, for example:
postUpdate(VoiceFeedback, "Away mode engaged, temperature: " + Outside_Temperature.state + "degrees. Have a good day")
postUpdate(VoiceFeedback, "")
openHAB also has a more robust TTS system now, and can generate an audio stream that can be played through HABPanel if using the webaudio sink, check the official docs for more info.
