When changing the runtime.cfg based on this info… Cron based rules suddenly stop executing, I see an immediate change using the Karaf command in that post. I’ve used these settings for about a year, and my server has never had an issue with load…
openhab> config:list "(service.pid=org.eclipse.smarthome.threadpool)"
Pid: org.eclipse.smarthome.threadpool
BundleLocation: null
Properties:
discovery = 55
ruleEngine = 55
safeCall = 55
service.pid = org.eclipse.smarthome.threadpool
thingHandler = 55
But no matter how many threads I added to the pool, I always only saw 5 threads.
Before running rules:
openhab> shell:threads --list |grep "RuleEngine"
82224 │ pipe-grep "RuleEngine" │ RUNNABLE │ 56 │ 40
After running rules:
82223 │ pipe-grep "RuleEngine" │ TIMED_WAITING │ 59 │ 40
82249 │ ESH-RuleEngine-26 │ TIMED_WAITING │ 1 │ 0
82250 │ ESH-RuleEngine-27 │ TIMED_WAITING │ 1 │ 0
82251 │ ESH-RuleEngine-28 │ TIMED_WAITING │ 1 │ 0
82252 │ ESH-RuleEngine-29 │ TIMED_WAITING │ 1 │ 0
82253 │ ESH-RuleEngine-30 │ TIMED_WAITING │ 1 │ 0
Rules (repeated 10 times)
rule "Test1"
Item Virtual_Switch_1 received command
logDebug("Rules","Test1: Start")
Thread::sleep(10000)
logDebug("Rules","Test1: End")
Log:
2018-09-27 23:00:49.340 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test2: Start
2018-09-27 23:00:49.343 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test3: Start
2018-09-27 23:00:49.345 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test6: Start
2018-09-27 23:00:49.346 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test10: Start
2018-09-27 23:00:49.348 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test9: Start
2018-09-27 23:00:59.342 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test2: End
2018-09-27 23:00:59.346 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test3: End
2018-09-27 23:00:59.352 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test4: Start
2018-09-27 23:00:59.349 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test9: End
2018-09-27 23:00:59.348 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test6: End
2018-09-27 23:00:59.347 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test10: End
2018-09-27 23:00:59.359 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test5: Start
2018-09-27 23:00:59.346 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test8: Start
2018-09-27 23:00:59.360 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test7: Start
2018-09-27 23:00:59.361 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test1: Start
2018-09-27 23:01:09.359 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test4: End
2018-09-27 23:01:09.361 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test8: End
2018-09-27 23:01:09.362 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test1: End
2018-09-27 23:01:09.361 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test5: End
2018-09-27 23:01:09.362 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - Test7: End
So, for some reason OH is not using the configured number of thread pools. Looks like a bug to me, so I opened an issue. I’m using snapshot 1372.
In case anyone is curious, JSR223-Jython does not have the same thread pool limitations, I setup 10 of these rules in JSR223-Jython (note the cool new decorators)…
@rule("Test: Test 1")
@when("Item Virtual_Switch_1 received command")
def threadTest1(event):
log.debug("JSR223: Test 1: start")
sleep(10)
log.debug("JSR223: Test 1: end")
And here is the log:
2018-09-27 22:48:58.129 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 2: start
2018-09-27 22:48:58.130 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 9: start
2018-09-27 22:48:58.132 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 4: start
2018-09-27 22:48:58.134 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 8: start
2018-09-27 22:48:58.134 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 1: start
2018-09-27 22:48:58.135 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 10: start
2018-09-27 22:48:58.136 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 6: start
2018-09-27 22:48:58.137 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 7: start
2018-09-27 22:48:58.140 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 5: start
2018-09-27 22:48:58.141 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 3: start
2018-09-27 22:49:08.131 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 9: end
2018-09-27 22:49:08.132 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 2: end
2018-09-27 22:49:08.133 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 4: end
2018-09-27 22:49:08.134 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 8: end
2018-09-27 22:49:08.135 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 1: end
2018-09-27 22:49:08.135 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 10: end
2018-09-27 22:49:08.137 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 6: end
2018-09-27 22:49:08.137 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 7: end
2018-09-27 22:49:08.141 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 5: end
2018-09-27 22:49:08.141 [DEBUG] [org.eclipse.smarthome.model.script.Rules] - JSR223: Test 3: end
