Hi all,
my setup is rather stable (3.2) running for weeks but from time to time InfuxDB (1.8.6) seems to conflict with Openhab. I get notified as soon as i do not see any graphs (basic graph, not grafana) in the GUI…
Looking into the logs i see a lot of errors. To me it looks like InfluxDB does have problems with openhab to connect. Does anyone else experience such behaviour? After a reboot all is fine again. Thanks for your thoughts. Norbert
2022-01-04 10:04:55.335 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'smartcontrol-4' failed: size=95 offset=0 byteCount=102 in smartcontrol
2022-01-04 10:04:55.341 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'smartcontrol-5' failed: java.net.ProtocolException: Unexpected status line: 1 400 Bad Request in smartcontrol
2022-01-04 10:04:55.808 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'smartcontrol-5' failed: java.net.ProtocolException: Unexpected status line: togen.PVng5sumGET /query?db=openhab_db&epoch=ms&q=Con
tent-Type: text/plain; charset=utf-8
2022-01-04 10:04:55.811 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'default-17' failed: java.net.ProtocolException: Unexpected status line: utf-8 in default
2022-01-04 10:04:55.820 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'smartcontrol-4' failed: java.net.ProtocolException: Unexpected status line: orization: Basic b3BlbmhhYGET /query?db=openhab_db&ep
och=ms&q=Connection: close
2022-01-04 10:04:56.376 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'default-10' failed: java.net.ProtocolException: Unexpected status line: rization: Basic b3BlbmhhY HTTP/1.1 in default
2022-01-04 10:04:58.319 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'default-17' failed: java.net.ProtocolException: Unexpected status line: ery?db=openhab_db&epoch=ms&q= in default
2022-01-04 10:04:58.328 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'smartcontrol-5' failed: java.net.ProtocolException: Unexpected status line: 8 in smartcontrol
2022-01-04 10:04:58.337 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'smartcontrol-4' failed: java.io.IOException: unexpected end of stream on http://127.0.0.1:8086/... in smartcontrol
2022-01-04 10:04:58.374 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'default-10' failed: java.net.ProtocolException: Unexpected status line: /3.14.9 in default
2022-01-04 10:04:58.800 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'default-17' failed: java.net.ProtocolException: Unexpected status line: ost: 127.0.0.1:8086 in default
2022-01-04 10:04:58.812 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'smartcontrol-5' failed: java.net.ProtocolException: Unexpected status line: coding: gzip in smartcontrol
2022-01-04 10:04:58.813 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'smartcontrol-4' failed: null in smartcontrol
2022-01-04 10:05:00.126 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
