I implemented a persistence simply writing some values on change and others every 1 minute. So this works:
// Persistence Strategien haben einen Namen und eine Definition
Strategies {
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
every5Minutes : "0 0/1 * * * ?"
// Wenn bei einem unten definierten Item keine Strategie angebeben ist,
// wird die Default-Liste angewendet
default = everyChange
Items {
Night_Light_Brightness_Tobias : strategy = everyChange
Heating_LivingRoom, Heating_Kitchen : strategy = every5Minutes
and it writes periodic date at e.g. 21:00h, 21:01h, 21:02h… (21:00h was just an example, it records this way around the clock…) BUT
Setting the cron job to two minutes to get data at e.g. 21:00h, 21:02h, 21:04h…
every5Minutes : "0 0/2 * * * ?"
or at 21:00h, 21:05h, 21:015h…
every5Minutes : "0 0/5 * * * ?"
fails and the persistence stops to write the periodic data.
# D A T A B A S E C O N F I G
# Some URL-Examples, 'service' identifies and activates internally the correct jdbc driver.
# required database url like 'jdbc:<service>:<host>[:<port>;<attributes>]'
# url=jdbc:derby:./testDerby;create=true
# url=jdbc:h2:./testH2
# url=jdbc:hsqldb:./testHsqlDb
# url=jdbc:mariadb://192.168.0.1:3306/testMariadb
# url=jdbc:mysql://192.168.0.1:3306/testMysql
# url=jdbc:postgresql://192.168.0.1:5432/testPostgresql
url=jdbc:sqlite:sqlite/testSqlite.db
# url=
Basically, this SQlite file is indeed storing the data (with the one minute rule), so the service itself is running well…
Ok, that seems to work, but the service only starts after the next full hour… is this possible? I’ll let it run tonight.
Btw.: That web page is really useful - thanks
