Hi there,
The squeezebox control and the playPause is not working for me.
I can send commands via the playPause channel, but nothing is received.
The state in openhab is not valid when i play something over the squeezebox directly.
Can somebody help? Is it working for somebody?
I answer the question myself. The control linked Item was of wrong type (must be player, not Switch)
The playPause channel isn’t fully working it does not receive the updates from external, but the control channel does if correctly configured.
@digitaldan: Maybe you can fix the playPause channel or remove it, nobody can use it because it’s not listed here: http://docs.openhab.org/addons/bindings/squeezebox/readme.html#channels
