I do the same thing (Doorbird doorbell triggers doorbell sound on pCP), although there’s a Russound zone controller in the mix, too. But that should not matter.
This is exactly what it’s supposed to do (with one exception). In some cases (I’ve seen it happen with Pandora, but it may happen with other streaming services), when it resumes playing it skips to the next song rather that pick up where it was paused. However, I believe this is an issue with the LMS.
This is not good. Does it happen all the time, or just sometimes? Do you have a debug log from when it happens.
Also, what version of LMS and Squeezelite are you running?
Hi, I stumbled over that topic because for my squeezebox setup the notifications are working, however, when the notification is finished, the music resumes but with volume 0…
LMS version: Logitech Media Server Version: 8.1.1 - 1610364019
and OH3
Event Log:
2021-04-29 12:39:52.873 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Doorbell_Pressed' changed from OFF to ON
2021-04-29 12:39:52.995 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Volume' changed from 3 to 50
2021-04-29 12:39:52.998 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Control' changed from PLAY to PAUSE
2021-04-29 12:39:52.998 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Stop' changed from OFF to ON
2021-04-29 12:39:53.075 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Volume' changed from 50 to 19
2021-04-29 12:39:55.100 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_CurrentPlayingTime' changed from 10675 to 0
2021-04-29 12:39:55.340 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Control' changed from PAUSE to PLAY
2021-04-29 12:39:55.341 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Stop' changed from ON to OFF
2021-04-29 12:39:56.701 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_CurrentPlayingTime' changed from 0 to 1
2021-04-29 12:39:57.702 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_CurrentPlayingTime' changed from 1 to 2
2021-04-29 12:39:58.048 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_CurrentPlayingTime' changed from 2 to 0
2021-04-29 12:39:58.050 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Duration' changed from 0 to 6
2021-04-29 12:39:58.051 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Title' changed from Herr Inspektor to Notification
2021-04-29 12:39:58.092 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_AlbumArt' changed from raw type (image/png): 28208 bytes to raw type (image/png): 43400 bytes
2021-04-29 12:39:58.093 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Radio' changed from Hitradio Ö3 88.6 (Top 40/Pop) to
2021-04-29 12:39:58.093 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Artist' changed from Seiler und Speer to
2021-04-29 12:39:59.702 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_CurrentPlayingTime' changed from 0 to 1
2021-04-29 12:40:00.703 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_CurrentPlayingTime' changed from 1 to 2
2021-04-29 12:40:01.703 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_CurrentPlayingTime' changed from 2 to 3
2021-04-29 12:40:02.113 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Control' changed from PLAY to PAUSE
2021-04-29 12:40:02.113 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Stop' changed from OFF to ON
2021-04-29 12:40:02.133 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Speaker_Kueche_Volume' changed from 19 to 0
Any idea what could solve the issue? Any presets to make for volume? But it should normally resume with the previous set volume correct? Thx
