mhilbush
(Mark)
October 24, 2018, 12:27pm
41
Thanks. Hopefully, it will happen in minutes and not days.
This is the version Iām running, BTW.
Normally, the playlist message from the LMS has the form mac-address playlist [1 or more additional arguments]
In your case, the LMS appears to be sending just mac-address playlist
, which isnāt defined in the LMS api spec. I donāt understand why this would be happening.
mhilbush
(Mark)
October 24, 2018, 12:37pm
42
I opened an issue for this.
jmccoy555
(jmccoy555)
October 24, 2018, 12:44pm
43
Here you go. If was working, I turned a few players on and off, and then left it and it stopped working.
So it looks like it gets a message that doesnāt contain a mac address⦠hummm
> 2018-10-24 13:34:06.205 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist pause 1
> 2018-10-24 13:34:08.509 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist pause 0
> 2018-10-24 13:35:44.264 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist open http%3A%2F%2Fa.files.bbci.co.uk%2Fmedia%2Flive%2Fmanifesto%2Faudio%2Fsimulcast%2Fhls%2Fuk%2Fsbr_high%2Fak%2Fbbc_radio_two.m3u8
> 2018-10-24 13:35:44.265 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist open http%3A%2F%2Fa.files.bbci.co.uk%2Fmedia%2Flive%2Fmanifesto%2Faudio%2Fsimulcast%2Fhls%2Fuk%2Fsbr_high%2Fak%2Fbbc_radio_two.m3u8
> 2018-10-24 13:35:44.526 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist newsong http%3A%2F%2Fa.files.bbci.co.uk%2Fmedia%2Flive%2Fmanifesto%2Faudio%2Fsimulcast%2Fhls%2Fuk%2Fsbr_high%2Fak%2Fbbc_radio_two.m3u8 0
> 2018-10-24 13:36:05.988 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist open http%3A%2F%2Fa.files.bbci.co.uk%2Fmedia%2Flive%2Fmanifesto%2Faudio%2Fsimulcast%2Fhls%2Fuk%2Fsbr_high%2Fak%2Fbbc_radio_two.m3u8
> 2018-10-24 13:36:05.989 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist open http%3A%2F%2Fa.files.bbci.co.uk%2Fmedia%2Flive%2Fmanifesto%2Faudio%2Fsimulcast%2Fhls%2Fuk%2Fsbr_high%2Fak%2Fbbc_radio_two.m3u8
> 2018-10-24 13:36:06.217 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist newsong http%3A%2F%2Fa.files.bbci.co.uk%2Fmedia%2Flive%2Fmanifesto%2Faudio%2Fsimulcast%2Fhls%2Fuk%2Fsbr_high%2Fak%2Fbbc_radio_two.m3u8 0
> 2018-10-24 13:36:24.755 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist pause 1
> 2018-10-24 13:36:31.700 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 playlist pause 0
> 2018-10-24 13:38:35.338 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: subscribe playlist
mhilbush
(Mark)
October 24, 2018, 12:47pm
44
Interesting. I didnāt expect that. I wonder what generates that subscribe message⦠Iāll look into it.
I have what I need to you can go back to INFO level logging.
Thanks!!
mhilbush
(Mark)
October 24, 2018, 12:52pm
46
One other thingā¦
From openhab.log, can you post the 10-20 lines that precede the line containing subscribe playlist
Thanks.
jmccoy555
(jmccoy555)
October 24, 2018, 1:17pm
47
Just waiting for it to happen again as I cleared the logsā¦
mhilbush
(Mark)
October 24, 2018, 1:22pm
48
Oh, sorry. I shouldāve asked for that info earlier.
Still trying to figure out what generates the subscribe playlist
command, since I canāt see it coming from the binding⦠Do you have anything (other than openHAB) thatās used to control the LMS? Smartphone app?
Sending subscribe playlist
to the LMS CLI directly, Iām also able reproduce another problem that was reported on the forum.
jmccoy555
(jmccoy555)
October 24, 2018, 1:24pm
49
It looks pretty repeaative. Let me know if you need a filter. Iāll leave it running as is for now this time
> 2018-10-24 14:20:37.312 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rescan%3A1'
> 2018-10-24 14:20:37.312 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3ABedroom-Master'
> 2018-10-24 14:20:37.312 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
> 2018-10-24 14:20:37.313 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.10.30.100%3A40158'
> 2018-10-24 14:20:37.313 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A0'
> 2018-10-24 14:20:37.313 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'remote%3A1'
> 2018-10-24 14:20:37.313 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'current_title%3Ahttp%3A%2F%2Fa.files.bbci.co.uk%2Fmedia%2Flive%2Fmanifesto%2Faudio%2Fsimulcast%2Fhls%2Fuk%2Fsbr_high%2Fak%2Fbbc_radio_two.m3u8'
> 2018-10-24 14:20:37.314 [TRACE] [ebox.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlayingTime for thing squeezebox:squeezeboxplayer:squeeze:bansteadBedroom1 with mac b8:27:eb:ed:87:ba to state 120
> 2018-10-24 14:20:37.314 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
> 2018-10-24 14:20:37.314 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
> 2018-10-24 14:20:37.314 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'sync_master%3Ab8%3A27%3Aeb%3Ac7%3A2a%3A45'
> 2018-10-24 14:20:37.314 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'sync_slaves%3Ab8%3A27%3Aeb%3Aed%3A87%3Aba%2Cb8%3A27%3Aeb%3A63%3Ab2%3A91%2Cb8%3A27%3Aeb%3A49%3Ae4%3A6c%2Cb8%3A27%3Aeb%3A8a%3Ad3%3Af0%2Cb8%3A27%3Aeb%3$
> 2018-10-24 14:20:37.315 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
> 2018-10-24 14:20:37.315 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A0'
> 2018-10-24 14:20:37.315 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1540370508.85623'
> 2018-10-24 14:20:37.315 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
> 2018-10-24 14:20:37.316 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'remoteMeta%3AHASH(0x561880f8ae60)'
> 2018-10-24 14:20:37.316 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A0'
> 2018-10-24 14:20:37.316 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A-94663233975696'
> 2018-10-24 14:20:37.316 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - b8:27:eb:ed:87:ba: URL for cover art is http://10.10.1.105:9000/html/images/radio.png
> 2018-10-24 14:20:37.360 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: b8%3A27%3Aeb%3Ac7%3A2a%3A45 status - 1 subscribe%3A10 tags%3AyagJlNKjc rescan%3A1 player_name%3AGarage player_connected%3A1 player_ip%3A10.10.30.46%3A36290 power$
> 2018-10-24 14:20:37.361 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'b8%3A27%3Aeb%3Ac7%3A2a%3A45'
> 2018-10-24 14:20:37.361 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'status'
> 2018-10-24 14:20:37.362 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type '-'
> 2018-10-24 14:20:37.362 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type '1'
> 2018-10-24 14:20:37.362 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'subscribe%3A10'
> 2018-10-24 14:20:37.363 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'tags%3AyagJlNKjc'
> 2018-10-24 14:20:37.363 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rescan%3A1'
> 2018-10-24 14:20:37.364 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_name%3AGarage'
> 2018-10-24 14:20:37.364 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_connected%3A1'
> 2018-10-24 14:20:37.364 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'player_ip%3A10.10.30.46%3A36290'
> 2018-10-24 14:20:37.365 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'signalstrength%3A0'
> 2018-10-24 14:20:37.365 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'remote%3A1'
> 2018-10-24 14:20:37.366 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'current_title%3Ahttp%3A%2F%2Fa.files.bbci.co.uk%2Fmedia%2Flive%2Fmanifesto%2Faudio%2Fsimulcast%2Fhls%2Fuk%2Fsbr_high%2Fak%2Fbbc_radio_two.m3u8'
> 2018-10-24 14:20:37.366 [TRACE] [ebox.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlayingTime for thing squeezebox:squeezeboxplayer:squeeze:bansteadGarage with mac b8:27:eb:c7:2a:45 to state 120
> 2018-10-24 14:20:37.367 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'rate%3A1'
> 2018-10-24 14:20:37.367 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'can_seek%3A1'
> 2018-10-24 14:20:37.368 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'sync_master%3Ab8%3A27%3Aeb%3Ac7%3A2a%3A45'
> 2018-10-24 14:20:37.368 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'sync_slaves%3Ab8%3A27%3Aeb%3Aed%3A87%3Aba%2Cb8%3A27%3Aeb%3A63%3Ab2%3A91%2Cb8%3A27%3Aeb%3A49%3Ae4%3A6c%2Cb8%3A27%3Aeb%3A8a%3Ad3%3Af0%2Cb8%3A27%3Aeb%3$
> 2018-10-24 14:20:37.369 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20mode%3Aoff'
> 2018-10-24 14:20:37.369 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'seq_no%3A0'
> 2018-10-24 14:20:37.369 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist_timestamp%3A1540370508.85623'
> 2018-10-24 14:20:37.370 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'digital_volume_control%3A1'
> 2018-10-24 14:20:37.370 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'remoteMeta%3AHASH(0x561881301250)'
> 2018-10-24 14:20:37.370 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'playlist%20index%3A0'
> 2018-10-24 14:20:37.371 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Unhandled status message type 'id%3A-94663233975696'
> 2018-10-24 14:20:37.371 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - b8:27:eb:c7:2a:45: URL for cover art is http://10.10.1.105:9000/html/images/radio.png
> 2018-10-24 14:20:39.135 [TRACE] [ebox.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlayingTime for thing squeezebox:squeezeboxplayer:squeeze:bansteadGarage with mac b8:27:eb:c7:2a:45 to state 121
> 2018-10-24 14:20:40.136 [TRACE] [ebox.handler.SqueezeBoxPlayerHandler] - Updating channel currentPlayingTime for thing squeezebox:squeezeboxplayer:squeeze:bansteadGarage with mac b8:27:eb:c7:2a:45 to state 122
> 2018-10-24 14:20:40.914 [TRACE] [ebox.handler.SqueezeBoxServerHandler] - Message received: subscribe playlist
mhilbush
(Mark)
October 24, 2018, 1:28pm
50
Hmm. Can you go back a little farther in the log. Try looking for the string Sending command
jmccoy555
(jmccoy555)
October 24, 2018, 1:30pm
51
Do you want the whole log file?
2018-10-24 14:14:09.730 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:14:09.731 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: favorites items 0 100
2018-10-24 14:14:09.731 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: listen 1
2018-10-24 14:14:09.791 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:8a:d3:f0 status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:14:09.801 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:c7:2a:45 status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:14:09.803 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:63:b2:91 status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:14:09.811 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:14:49:01 status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:14:09.815 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:14:09.828 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:49:e4:6c status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:14:17.464 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:c7:2a:45 power 0
2018-10-24 14:14:19.355 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:c7:2a:45 power 1
2018-10-24 14:14:19.693 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:14:57.513 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:c7:2a:45 power 0
2018-10-24 14:14:59.008 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:c7:2a:45 power 1
2018-10-24 14:15:19.694 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:16:19.696 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:16:27.302 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 1
2018-10-24 14:16:28.407 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 0
2018-10-24 14:16:46.378 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 1
2018-10-24 14:16:47.481 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 0
2018-10-24 14:17:19.697 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:17:51.828 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 1
2018-10-24 14:17:52.830 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 0
2018-10-24 14:17:54.040 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 1
2018-10-24 14:17:55.153 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 0
2018-10-24 14:18:19.698 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:18:35.960 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 1
2018-10-24 14:18:36.877 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba power 0
2018-10-24 14:19:19.698 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:20:19.699 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:27:18.675 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:27:18.675 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: favorites items 0 100
2018-10-24 14:27:18.675 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: listen 1
2018-10-24 14:27:18.683 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:8a:d3:f0 status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:27:18.685 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:c7:2a:45 status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:27:18.686 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:63:b2:91 status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:27:18.688 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:14:49:01 status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:27:18.690 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:ed:87:ba status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:27:18.692 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:49:e4:6c status - 1 subscribe:10 tags:yagJlNKjc
2018-10-24 14:27:19.706 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
2018-10-24 14:27:22.830 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:49:e4:6c power 1
2018-10-24 14:27:25.654 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:49:e4:6c power 0
2018-10-24 14:27:27.189 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:c7:2a:45 power 1
2018-10-24 14:28:19.707 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: players 0
mhilbush
(Mark)
October 24, 2018, 1:34pm
52
Sure.
That subscribe playlist
command doesnāt appear to be coming from the binding , as there would be a Sending command: subscribe playlist
in the log.
Do you use any other apps for controlling the LMS? Smartphone app, for example?
jmccoy555
(jmccoy555)
October 24, 2018, 1:49pm
53
Squeezer which Iāve been using for years and⦠ah I tried an app on Windows 10⦠let me turn off my laptop. Itās been behaving since so far!!!
Canāt upload the log on here, hereās a link - https://cloud.mcy.space/s/innqJ7fXmZEjyfr
jmccoy555
(jmccoy555)
October 24, 2018, 1:58pm
55
mhilbush:
Which app?
Thatās it, as soon as I turn on my laptop - Message received: subscribe playlist
Its called Squeeze 11 (and now being uninstalled)!!
mhilbush
(Mark)
October 24, 2018, 2:07pm
56
Sweet. Found it!
Iāll make a fix, but until the next milestone or release build, it will only be available in the snapshot release.
jmccoy555
(jmccoy555)
October 24, 2018, 2:10pm
57
Great, thanks⦠might jump on the 2.4 train then.
mhilbush
(Mark)
October 24, 2018, 2:47pm
58
I submitted a PR containing a fix for this. Iāll post back here when itās merged and included in a snapshot release.
mhilbush
(Mark)
October 26, 2018, 7:19pm
59
@jmccoy555 FYI, the fix is included in snapshot build 1401.
jmccoy555
(jmccoy555)
November 2, 2018, 6:54pm
60
Hi @mhilbush thanks; Iāll try and give it a test as soon as I get a min.
