But the 2 files i created its : openhabian:openhab ???
Changed it it openhab:openhab for both files
Have i now change this for each created file to openhab:openhab ???
I don’t use openhabian so try to search for an answer on the forum
the CurrentPlayingTime itself will never change, the system logs the data provided by the binding,
don’t be confused with the displayed item state! these are two different things one is a value the other is how the value is displayed for the user, keep that in mind!
You have to take a look at the widget to see if the time is converted by your mmss.js script…
Sorry but have you read the bindings documentation? if not it’s just a click away
But to answer your question, it’s not a dummy item, it’s not a player channel so you don’t find it in your things configuration. It’s a server channel.
You can reach this channel here:
// Server
String SqueezeServerListFavorite "List Favorites" (gSqueezeServer) {channel="squeezebox:squeezeboxserver:<your server name here>:favoritesList"}
please have a deeper look at the docs
cheers,
Dan
edit:
by the way… you have to fill this list with your favourites on the server side - this is a squeezebox feature… if you don’t add favourites to your squeezebox server, your list will remain empty.
Sorry
I try to understand but as a not IT professional it´s not always so easy to understand everything in the right direction.
But thanks again for your patience.
By the way: I have now also my modell textual configured. Was a great tip.
Really happy to be textual again.
Was not so a big thing as i realized the tagging in the right way.
Sometimes difficult to find the right syntax but all in all ´m satisfight with it as it is easier to handle for me.
No problem Karl… that’s what we’re here for - to help each other!
Nice that you got your model running.
The documentation is a good tool to find answers to questions in general, this is why I pointed you there. Actually a good point to start because most of the questions are covered by the docs nowadays…
My status up to now: player are choiseable and plays,
Cover art, player, volume,and power on off works.
Favorites show NULL as i have no faforites list definet on the server ( up to now)
Now the but: Track info doesn´t work as expected
When i hear radio stream there is no value in duration so i changed this to currplayingtime for test and this workes
Title and artist are always empty. But used the same suffix for all items ?
What me confuses when i customise the widget and i put in a static widget title (first line) always the title suffix ( 8.input line) also gets filled with the same value ?
For my understanding static title should be the label of the whole widget.
And in the line title suffix i should be able to fill in the necessary prefix ? When i change this also static widget title is changed ?
When i look in Main UI the item Artist is correct filled in.
Where do these underscores in your Names come from??
Should be
SqueezeWintergartenYear
not
Squeeze_Wintergarten_Year
maybe this is the reason why your information is not displayed - just a guess
or maybe you have a typo somewhere in your config and duplicated this error for every player via copy/paste - I don’t know…
the according player item-names should follow this structure:
Prefix-Playername-Suffix
maybe this is a little misleading, although it becomes clear with the example that follows. Nevertheless, I would maybe change that to “PlayerPlayernameSuffix”
