to be honest I’m not reallly sure what your issue is about… but it has nothing to do with the naming of your things! I guess the item-names which are bound to your thing’s channels are problematic.
Try to bind the items manually and give them certain names that match the structure PrefixPlayernameSuffix e.g. “SqueezeWohnzimmerFavorite” or “SqueezeKücheMute” and try to avoid spaces and underscores.
I will try to follow your new way - it was so easy to let the system do all the work
But it seems that was not the best way to understand what´s happening - thanks for your fast help!
So far it seems “squeezekuecheAlbum” is ok… what have you entered at the widget configuration? Maybe a typo regarding to upper/lowercase letters? To avoid that, I personally use only the first letter in uppercase and the rest in lowercase, for prefix name and suffix, and use this at the widget-config too.
e.g. SqueezeKuecheAlbum
Make sure the widget config matches the naming from your items!
I think for now you can ignore the warnings in the logs… these are no errors. Can you specify what exactly is not working for you except these annoying warnings?
