i have burned the file image on the sd card and inserted it into the raspberry . i have also checked the IP of the raspberry , then tried to ssh to my raspberry using its IP in order to check the booting progress but i have given this message !!!
Because sshd is not enabled by default.
Further Edit:
You burned what file? A random text file? openHABian, Raspbian, win10 IOT, FooBar?
Please provide better information.
How to enable sshd?
https://www.raspberrypi.org/documentation/remote-access/ssh/README.md
openhabian image , but not the newest version , i’m using V1.1 .
Why not the latest… download the latest and post results.
If its the openhabian Rpi image, SSH is enabled by default. (there is a empty ssh file on root)
I think this may have changed very long time ago. (I cant recall when it didnt have SSH enabled as default. I have been using openhab (openhabian images since openHAB 2.2.).
