Hello everyone,
I’ve some issues with the freebox binding. Maybe it’s an SSL certificate issue.
I need to add a new Authority to my certficates.
My question is: where is the cert file used by openhab bindings ? I’m running openhabian on a raspberry PI.
I found this one
/usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/security/cacerts
Is this the good one ?
Thank you
sudo keytool -import -file /home/openhabian/freeboxRSA.crt -trustcacerts -alias Freebox4 -keystore /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/security/cacerts
