After updating the application to openHAB 2.12.1 I cannot connect from outside LAN to openhab2. I have the message “SSL handshaking failed”.
On the second phone with the December 2019 app, the connection works normally.
I have external IP and correctly redirected ports. How to fix it?
What phone are you using?
Is the ssl certificate on your proxy server expired?
Huawei P30
How to check? I did not install additional certificates.
You did not say how you connect your app to openHAB over the Internet so I made a guess.
It helped unblocking the port on 8443. Thank you.
I hope would are not exposing your unsecured system to the Internet. That is asking for big trouble.
OpenHAB is insecure by design and there is a documentation page on ways to secure it better. I personally use a reverse proxy secured by a logon.
I think we both agree that openHAB should not be directly exposed to the Internet.
Correct, you shouldn’t do that.
