hey folks,
bit offtopic, but still … can be worse
wondering if someone got this IPS
working with RPI?
hey folks,
working with RPI?
You made a wrong turn This is not the Raspberry Pi forum.
I believe you can run spi devices from the pi GPIO but I could be wrong. If this is a common device, there will be a library somewhere
so… what, DIY hardware, there is no need to comment everything when you dont have much to say, rly
yeah sure i can, library is bit of pain honestly, all i found so far is arduino or not working on rpi much
@kriznik, there is no need to reply to a comment is suck a way, bruce’s comment was valid. It is off topic and should have been posted is a pi forum.
@Bruce_Osborne, kriznic is active on the forum and introduced the topic as “bit off topic” in his first post. Your comment was valid if a little blunt.
