Start Amazon Echo Routine from OH
I am using OH 4.3 (windows) with the amazon echo binding. In general the echo and OH is working but I do have one issue when I try to start an echo-routine from OH.
This means I have an OH-rule with the code:
configuration: {}
triggers: []
conditions: []
actions:
  - id: "2"
    configuration:
      itemName: Amazon_Echo_Dot_Started_eine_Routine
      command: Gehen
    type: core.ItemCommandAction
this code shall start the Amazon Echo routine with the name “Gehen”. The routine in the Amazon Echo is working and I can run it. The problem is that I can not start this routine from OH. In the event log I see following:
2025-01-02 18:16:47.508 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Amazon_Echo_Dot_Started_eine_Routine' received command Gehen
2025-01-02 18:16:47.508 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Amazon_Echo_Dot_Started_eine_Routine' predicted to become Gehen
2025-01-02 18:16:47.508 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Amazon_Echo_Dot_Started_eine_Routine' updated to Gehen
2025-01-02 18:16:47.508 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Amazon_Echo_Dot_Started_eine_Routine' changed from  to Gehen
2025-01-02 18:16:48.757 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Amazon_Echo_Dot_Started_eine_Routine' updated to
2025-01-02 18:16:48.757 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Amazon_Echo_Dot_Started_eine_Routine' changed from Gehen to
What I am doing wrong with the OH-rule?
Is your item connected to the startRoutine-channel of your echo thing? You will only see this channel if you enable “show advanced” in the channel tab.
Yes it is… in the OH-Log I see this entry when I run the rule:
 [mazonechocontrol.internal.Connection] - Routine Gehen not found
“Gehen” is the routine which I would like to start in the amazon echo app. There I have the routine “Gehen” implemented and it is running. What I do not understand why OH writes such a log that the routine has not been found?!
what I found out is that some routines are working but some do not. The ones which are not working returns the OH-log with the specific routine name:
What could be the issue here?
Do you use different accounts on your smartphone vs. openhab ?
no, it is the same account. On the smartphone I do have about 10 routines whereas 8 are working when calling from OH. The rest is not working while I see the “strange” OH-log (see above).
Maybe it’s a problem with reserved words of Alexa?
But one thing you could do as a workaround is to define a triggering sentence in the Alexa app and then from openhab call this sentence with an item linked to the textCommand-channel.
I thought about the same but the solution for me was:
On the smartphone I renamed the routine “abc” and also used the same name “abc” for the routine “If”… This means you say “Alexa, abc”.
This approach worked at the end.
Could it be that is just was a problem of ‘correct’ spelling Gehen vs. gehen ?
I had as far as I remember at least one case when something stopped to work that worked before. Then in the alexa app I checked the logs of what alexa understood and I had to correct the spelling resp. the case of the spelling to make it working again.
Yes, this is also very likely.
