Hi openhab Community,
like to say hello and great to have you und your very great software.
Unfortunatelly i get following error when i try to start openhab2 in debug mode.
I use openhab 2.2 on raspi3 with zway binding.
java version "1.8.0_151"
Java™ SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot™ Client VM (build 25.151-b12, mixed mode)
Thanks in advance,
Hannes
2018-01-07 11:03:32.831 [WARN ] [org.jline ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
2018-01-07 11:03:39.458 [WARN ] [.core.internal.i18n.I18nProviderImpl] - Could not set new location, keeping old one:
2018-01-07 11:03:39.471 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to de_DE, Location set to null, Time zone set to Europe/Berlin
2018-01-07 11:03:39.598 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-01-07 11:03:41.275 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.178.40
2018-01-07 11:03:41.306 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.178.40
2018-01-07 11:03:41.499 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.115.1:8080
2018-01-07 11:03:41.510 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.115.1:8443
2018-01-07 11:03:52.769 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-01-07 11:03:55.426 [INFO ] [nding.zway.handler.ZWayBridgeHandler] - Initializing Z-Way bridge …
2018-01-07 11:03:56.403 [INFO ] [nding.zway.handler.ZWayBridgeHandler] - Z-Way bridge successfully authenticated
2018-01-07 11:04:06.632 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-01-07 11:04:06.838 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-01-07 11:04:07.111 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-01-07 11:04:07.594 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-01-07 11:04:11.183 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
java.net.SocketException: Socket closed
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?]
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) [?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:171) [?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) [?:?]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) [?:?]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) [?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) [?:?]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940) [?:?]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) [?:?]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:71) [?:?]
at su.litvak.chromecast.api.v2.Channel.read(Channel.java:411) [199:org.openhab.binding.chromecast:2.2.0]
at su.litvak.chromecast.api.v2.Channel.access$200(Channel.java:50) [199:org.openhab.binding.chromecast:2.2.0]
at su.litvak.chromecast.api.v2.Channel$ReadThread.run(Channel.java:132) [199:org.openhab.binding.chromecast:2.2.0]
2018-01-07 11:04:11.232 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - <-- null payload in message
2018-01-07 11:04:11.233 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while closing channel
2018-01-07 11:04:11.256 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
2018-01-07 11:04:11.260 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - <-- null payload in message
2018-01-07 11:04:11.261 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while closing channel
2018-01-07 11:04:11.515 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-01-07 11:04:47.261 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
java.lang.NumberFormatException: null
at java.math.BigDecimal.(BigDecimal.java:596) ~[?:?]
at java.math.BigDecimal.(BigDecimal.java:383) ~[?:?]
at java.math.BigDecimal.(BigDecimal.java:806) ~[?:?]
at org.eclipse.smarthome.core.library.types.DecimalType.(DecimalType.java:55) ~[?:?]
at org.openhab.binding.zway.handler.ZWayDeviceHandler.refreshChannel(ZWayDeviceHandler.java:360) ~[?:?]
at org.openhab.binding.zway.handler.ZWayDeviceHandler.handleCommand(ZWayDeviceHandler.java:634) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:243) ~[?:?]
at org.openhab.binding.zway.handler.ZWayDeviceHandler.channelLinked(ZWayDeviceHandler.java:392) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:290) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-01-07 11:04:50.070 [ERROR] [.zway.handler.ZWayZWaveDeviceHandler] - null
2018-01-07 11:04:50.100 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2018-01-07 11:04:50.939 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: Could not update state, because callback is missing
java.lang.IllegalStateException: Could not update state, because callback is missing
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateState(BaseThingHandler.java:303) ~[?:?]
at org.openhab.binding.zway.handler.ZWayDeviceHandler.refreshChannel(ZWayDeviceHandler.java:328) ~[?:?]
at org.openhab.binding.zway.handler.ZWayDeviceHandler.handleCommand(ZWayDeviceHandler.java:503) ~[?:?]
2018-01-07 11:04:51.221 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-01-07 11:04:51.262 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-01-07 11:04:51.322 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-01-07 11:04:51.376 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2018-01-07 11:04:51.858 [ERROR] [.zway.handler.ZWayZWaveDeviceHandler] - null
2018-01-07 11:04:52.401 [ERROR] [.zway.handler.ZWayZWaveDeviceHandler] - null
