To be kind of docker compliant. It is quite unexpected not to see the logs when starting a container.
docker logs openhab_container should display logs which is not the case
I understand Dockerfile should be adapted. Can you point me to the two other ways ?
As a workaround I suppose I could create a pipe to stdout for the three files audit.log, events.log, openhab.log
Of all the services I run in Docker I think only one does this. If it is a Docker standard it is one that few images seem to follow. Most services I use log to their own log file which you use volumes to get them out of the container.
You can tail -f the log files, or log into the Karaf console and display the logs from there.
Surprising, as it is all the opposite for me. Every container logs to stdout & stderr if not instruct otherwise (nginx, mosquitto, openvpn, elk, grafana, influxdb …)
Anyway, I found this as a solution:
In /openhab/userdata/etc/org.ops4j.pax.logging.cfg
