Hi all,
I’m configuring a Comfoair binding and I need, as written on note2 of the binding guide, to modify the start.sh
It is even available on openhab2 (the binding is for openhab1 but it is compatible with openhab2)? Otherwise, where can I set the new virtual port in order to make it available to openhab2?
Thanks!
This is the note:
"… If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0
where ttyAMA0 is the path to your serial port. Please be aware to change all scripts you might use for startup (debug, automatic start in linux,…) …"
