I’ve installed openHAB3 in Portainer (Docker) and want to access the filesystem via samba.
What I did: apt-get install samba samba-common-bin
and edit /etc/samba/smb.conf.
After that I start the service via service smbd start. But when I reboot the container, samba is not started automatically so I have to enter service smbd start after every restart.
I’ve read that I can chkconfig smbd on but this tells me bash: chkconfig: command not found.
Anyone having a hint for me? Thanks in advance!
Did you check ( with command testparm ) if the smb.conf is correct and does not contain any error ?
An other question: is samba installed inside of your container or outside/on host ?
I have the impression samba is installed on host and not inside your container.
For openHAB in the portainer, testparm shows that the smb.conf is correct; no errors.
But you are right, I run portainer in proxmox and samba / samba-common-bin is not installed over there.
