Running inclusion for the Zwave and Zigbee Bindings to add a device can be a logistics challenge. Discovery needs to be started in Habmin or PaperUI, and then you need to run to the device to put it into inclusion mode. This is what I setup so that I can just ask Alexa to turn on discovery. I use the HueEmulation Binding, but this should work with the skill too. This could easily be expanded for exclusion too.
Switch Zwave_Discovery "Z-Wave Discovery" ["Switchable"] {autoupdate="false"}
Switch Zigbee_Discovery "Zigbee Discovery" ["Switchable"] {autoupdate="false"}
rule "Start zwave discovery"
Item Zwave_Discovery received command
val String discoveryResponse = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -o /dev/null -s -w \"%{http_code}\" --connect-timeout 10 -m 10 -X POST --header \"Content-Type: application/json\" --header \"Accept: text/plain\" \"localhost:8080/rest/discovery/bindings/zwave/scan\"",10000)//start discovery
logDebug("Rules", "Start Zwave discovery: Response=[{}]",discoveryResponse)
rule "Start zigbee discovery"
Item Zigbee_Discovery received command
val String discoveryResponse = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -o /dev/null -s -w \"%{http_code}\" --connect-timeout 10 -m 10 -X POST --header \"Content-Type: application/json\" --header \"Accept: text/plain\" \"http://localhost:8080/rest/discovery/bindings/zigbee/scan\"",10000)//start discovery
logDebug("Rules", "Start Zigbee discovery: Response=[{}]",discoveryResponse)
