Starting Harmony Activity from OpenHab
I have read through the docs and forum posts and still can not pull this together…
I want to create a switch to start a Harmony Hub Activity.
I have installed the binding and added the hub as well as all of the devices to my system.
I queried the REST API looking for my activity but did not see it listed.
I find this as my channel ID for the HUB:
harmonyhub:hub:HarmonyHub:
And the activity I want to start is called Theatre
What is the syntax to create an item so that I can turn Theatre on?
Must I use rules?
This should be fairly simple but I am getting lost.
Thanks,
Squid
For triggering the activities you need the following
Things
Bridge harmonyhub:hub:xxxx "Harmony Hub" @ "Living Room" [ host="192.168.0.xxx" ]
Items
String Harmony_Activity         "Current Activity [%s]"     { channel="harmonyhub:hub:xxxx:currentActivity" }
My sitemap:
Switch item=Harmony_Activity label="Power Off" mappings=[ PowerOff="PowerOff" ]
Switch item=Harmony_Activity label="Activity" mappings=[ TV="TV", Kodi="Kodi",Radio="Radio" ]
Switch item=Harmony_Activity label="Activity" mappings=[ Chromecast="Chromecast", "Chromecast Audio"="Chromecast Audio"]
So simple change one of the above mappings to Theatre
Do I understand your format correctly (I’ve renamed a sample here)?
Switch item=Harmony_Activity label="Activity" mappings=[ activity_name_in_harmony_system="label_for_basic_ui"]
So why do you have two Activity lines? From what I can tell you could have just put all 5 of your mappings into a single line, right?
Correct!
I splitted it in 2 lines for better formatting on my mobile device. Otherwise I had to swipe to the right/left. Now everything is perfectly readable
Makes sense - each line in this file renders as a new row in the Basic UI (and thus in the mobile native app). Very helpful, thank you for posting!
