In my sitemap configuration file I have a selection defined as:
Selection item=KNXScenes icon=“house” mappings=[0=“Welcome”,1=“Good bye”]
When I start the UI for the first time the system sends the Welcome command on the KNX bus even though there is no previous state or selection made for KNXScenes, why is this? Can I make OH2 not send anything just because the sitemap is loaded by any means (rules/config/sitemap)?
You are correct, did quick check but missed that one.
Is there any way to initialize or set a value for the knxscenes at startup, i tried having a sendcommand with a dummy value at system start in rules but it didn’t seem to help. I saw that they fiddled with autoupdate as well with mixed success so I’ll try that at least.
Would be a hassle to create a wrapper with rules just to avoid this…
