Startup order of bundles and rules
If you look at the startup levels, Things are not initialized until start level 80. Both of these errors come from rules attempting to use an Action from a Thing that hasn’t been initialized yet. It’s not enough that the bundle be loaded, the Thing needs to be initialized and ONLINE too.
If these rules are triggered with a system started change to a system runlevel of 80 or greater. If these rules are not triggered with a system started or system runlevel trigger, you can use Delay Start [4.0.0.0;4.9.9.9] to disable those rules until a configured amount of time after runlevel 100 is reached, or Thing Status Reporting [4.0.0.0;4.9.9.9] to disable/enable the rules until the Things become ONLINE.
