Hi all,
I’m working on a rule that should initialize some dictionaries at startup. This worked initially but suddenly stopped working. I’ve upgraded to OH 2.5.9 and deleted tmp and cache; did several restarts of OH - but still the startup is not called. The file has been loaded and parsed - as other rules in the file are executed and no error is visible in openhab.log. Any ideas what might be wrong here?
The initialization is quite simple:
import java.util.Hashtable
val defaultCover = "http://192.168.0.73:8080/static/img/default-release-cd.png"
val _favoriten = new Hashtable<Integer, String>()
val _favoritenItems = new Hashtable<PlayerItem, StringItem>()
val _podcastItems = new Hashtable<Integer, StringItem>()
val loggerName="Radio.rules"
rule "Initialization"
System started
logInfo(fileName, "Initialization ...")
_favoriten.put(0, "SRF 1 Aargau Solothurn");
_favoriten.put(1, "SRF 2 Kultur");
_favoriten.put(2, "SRF 3");
_favoriten.put(3, "SRF 4 News");
_favoriten.put(4, "Radio Argovia");
_favoriten.put(5, "Radio Swiss Pop");
_favoriten.put(6, "Radio Swiss Jazz");
_favoriten.put(7, "SwissGroove")
_favoriten.put(8, "Gotha Lounge")
_favoritenItems.put(ItemRadioControlSchlafzimmer, ItemSonosFavoriteSchlafzimmer)
_favoritenItems.put(ItemRadioControlKueche, ItemSonosFavoriteKueche)
_favoritenItems.put(ItemRadioControlBad, ItemSonosFavoriteBad)
_favoritenItems.put(ItemRadioControlBastelzimmer, ItemSonosFavoriteBastelzimmer)
_favoritenItems.put(ItemRadioControlBuero, ItemSonosFavoriteBuero)
_podcastItems.put(0, ItemPodcastEchoDerZeit)
_podcastItems.put(1, ItemPodcastRegionalJournal)
_podcastItems.put(2, ItemPodcastPeterSchneider)
_podcastItems.put(3, ItemPodcastPopRoutes)
_podcastItems.put(4, ItemPodcastKontext)
_podcastItems.put(5, ItemPodcastInput)
_podcastItems.put(6, ItemPodcastForschungAktuell)
_podcastItems.put(7, ItemPodcastWissenschaftImBrennpunkt)
_podcastItems.put(8, ItemPodcastTatort)
_uriItems.put(ItemRadioControlSchlafzimmer, ItemRadioPlayUriSchlafzimmer)
_uriItems.put(ItemRadioControlKueche, ItemRadioPlayUriKueche)
_uriItems.put(ItemRadioControlBad, ItemRadioPlayUriBad)
_uriItems.put(ItemRadioControlBastelzimmer, ItemRadioPlayUriBastelzimmer)
_uriItems.put(ItemRadioControlBuero, ItemRadioPlayUriBuero)
ItemRadioSelectStation.postUpdate(-1)
ItemRadioSelectPodcast.postUpdate(-1)
Attached the complete file:
Radio.rules.txt (5.7 KB)
with kind regards,
Patrik
