just had the situation that my startup rules were executed even though OH2 was running since a few hours:
2016-09-17 14:57:00.628 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'WeatherTemperature' with state '20.40' in rrd4j database
2016-09-17 14:57:00.639 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Aeon_CO_Temperature' with state '24' in rrd4j database
2016-09-17 14:57:00.649 [DEBUG] [sistence.rrd4j.internal.RRD4jService] - Stored 'Thermostat_BA_SetTemp' with state '4.5' in rrd4j database
2016-09-17 14:57:28.821 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP DELETE request at 'items/zwave_device_a367f17a_node9_meter_watts' for the unknown item 'zwave_device_a367f17a_node9_meter_watts'.
2016-09-17 14:57:49.252 [INFO ] [smarthome.model.script.Heating.rules] - Setting default values at startup
2016-09-17 14:57:49.279 [INFO ] [smarthome.model.script.Heating.rules] - Current month is 9
2016-09-17 14:57:49.295 [INFO ] [smarthome.model.script.Heating.rules] - Setting Heating summer mode to ON
2016-09-17 14:57:52.860 [INFO ] [marthome.model.script.Presence.rules] - Setting default values at startup
2016-09-17 14:58:08.127 [INFO ] [marthome.model.script.Lighting.rules] - Setting default values at startup
Last action I did was trying to delete an auto-generated item at 14:57:28. (which failed for some reason…)
I am running OH2 just one or two snapshots before the beta4 release.
Any idea what could have caused this?
This is one of the startup rules:
rule "Set default presence settings on startup"
System started
logInfo("Presence.rules", "Setting default values at startup")
