just one last question, how can i troubleshoot this error?
2023-02-09 21:24:53.152 [ERROR] [al.handler.OMaticMachineThingHandler] - Failed to parse value from event: {"type":"UnDef","value":"UNDEF"} payload: {"type":"UnDef","value":"UNDEF"} stringValue: UNDEF
2023-02-09 21:25:08.814 [ERROR] [al.handler.OMaticMachineThingHandler] - Failed to parse value from event: {"type":"UnDef","value":"UNDEF"}
hey, your trick seems to work!
i had to clean many unused items, groups, rules and things (i should had to do this many time ago) and from yesterday no errors except the one above.
again this error that i cannot troubleshootā¦any idea @Seaside ?
thank you ver much for your great binding.
Can you please supply a version for openhab 4.0.0? I have tried both version from marketplace und BETA 2 from this thread. But i cannot add a thing with both versions.
Hi!
Yes I will add a 4.0.0 version at some point.I donāt have that much information yet, more than Iām myself using the binding and will switch to 4.0.0 in near future.
sorry for late answer, but finally i had time to check logs setting to DEBUG mode.
here you can find openhab.log openhab.log (390.8 KB)
let me know if can help you more.
Sorry for late response. So I guess Quantity type does not seem to work.
A quick fix is to use a numeric type, you could create a new numeric item, create a rule that posts the value when the quantity type is updated to the new numeric item.
I will try to see If I can fix it in the code, but donāt have a time frame of when, Iām working on 4.0 migration of my system and have somewhat limited time.
[ERROR] [c.internal.OMaticThingHandlerFactory] - bundle org.openhab.binding.omatic:4.0.0.202304191948 (239)[org.openhab.binding.omatic.internal.OMaticThingHandlerFactory(309)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77) ~[?:?]
hello and congratulations on your work, everything seems to be working fine to me, except that it doesnāt tell me the costs (I set 0.13 in the field). However, I cannot change the states in the page widget with the following expression:
I also inserted, in the metadata of the article STATE, the description of the mapping as written at the beginning of the post, but nothing, it remains ACTIVE
any help?
Thank you
Hi Iām seeing an empy page as well, the same as the screen snip from asdfsafd a few posts above and Iām also on OH 4.1.2
This is the first time I have installed this binding and have tried a restart and reboot but no luck.
Still not working. BTW: Iām using the Docker installation on a Synology. Log says
Could not determine bundle name from url: https://github.com/seaside1/omatic/releases/download/org.openhab.binding.omatic-3.x.x-BETA1/org.openhab.binding.omatic-3.x.x-BETA1.jar
I removed the binding, downloaded the latest release for openHAB 4 from here: Releases Ā· seaside1/omatic Ā· GitHub and copied the jar into the addons folder.
Same error after migrating to 4.2.1 and Bullseye (may have had error before - hadnāt been paying attention, but saw it in the log after migrating. Fixed it with the .jar file
