Dear Community,
since a couple of weeks started to configure my smart home setup. I got a lot of homematic stuff in my house (mostly switches) to controll other items. By reading my log view in the browser in order to figuring out where the problem is located I saw that the status of an homematic item ist toogleing.
For example:
In my rule I catch:
rule "LightOn"
when Item switch5_6_short changed from OFF to ON
exampleItem.send(ON)
The result will be that the Item switches from OFF to ON and a couple of seconds later the State will change from ON to OFF, without doing anything.
So in this case a changed the rule trigger to:
that was working fine for this case but did not solve my problem totally.
I bought a homematic 6 item switch in order to manage my lighting setup in the living room. The goal was to switch between different color setups with a switch case statement
rule "Lichtsteuerung EG++"
when Item switch_wohnzimmer_5_6fach_UL_kurz changed
switch(colorSceneCounterKueche.toString){
case "0":{
logInfo("davor",colorSceneCounterBad.toString)
LSTv_Color.send(leseLicht)
LSKueche_Color.send(leseLicht)
LIWohnSofa_Color.send(leseLicht)
LSSofa_Color.send(leseLicht)
LBWohnSchrank_Color.send(leseLicht)
colorSceneCounterKueche=colorSceneCounterKueche + 1
logInfo("dannach",colorSceneCounterKueche.toString)
case "1":{
LSTv_Color.send(spaLicht1)
LSKueche_Color.send(spaLicht2)
LIWohnSofa_Color.send(spaLicht2)
LSSofa_Color.send(spaLicht1)
LBWohnSchrank_Color.send(spaLicht2)
colorSceneCounterKueche = colorSceneCounterKueche + 1
case "2":{
LSTv_Color.send(sunsetLicht1)
LSKueche_Color.send(sunsetLicht2)
LIWohnSofa_Color.send(sunsetLicht2)
LSSofa_Color.send(sunsetLicht1)
LBWohnSchrank_Color.send(sunsetLicht2)
case "3":{
LSTv_Color.send(springLicht)
LSKueche_Color.send(springLicht)
LIWohnSofa_Color.send(springLicht)
LSSofa_Color.send(springLicht)
LBWohnSchrank_Color.send(springLicht)
case "4":{
logInfo("davor",colorSceneCounterKueche.toString)
LSTv_Color.send(nordLicht)
LSKueche_Color.send(nordLicht)
LIWohnSofa_Color.send(nordLicht)
LSSofa_Color.send(nordLicht)
LBWohnSchrank_Color.send(nordLicht)
case "5":{
LSTv_Color.send(tropicalLicht1)
LSKueche_Color.send(tropicalLicht2)
LIWohnSofa_Color.send(tropicalLicht1)
LSSofa_Color.send(tropicalLicht2)
LBWohnSchrank_Color.send(tropicalLicht2)
colorSceneCounterKueche = 0
default:{
colorSceneCounterKueche=0
The Problem is in this case that the Item will change his state twice and I am not able to run throw the listet states because the homematic switch jump over cases.
019-07-20 11:22:29.485 [vent.ItemStateChangedEvent] - switch_wohnzimmer_5_6fach_UL_kurz changed from OFF to ON
2019-07-20 11:22:29.497 [INFO ] [eclipse.smarthome.model.script.davor] - 5
2019-07-20 11:22:29.515 [ome.event.ItemCommandEvent] - Item 'LSTv_Color' received command 17,64,49
2019-07-20 11:22:29.525 [INFO ] [lipse.smarthome.model.script.dannach] - 0
2019-07-20 11:22:29.531 [ome.event.ItemCommandEvent] - Item 'LSKueche_Color' received command 333,35,49
2019-07-20 11:22:29.538 [ome.event.ItemCommandEvent] - Item 'LIWohnSofa_Color' received command 17,64,49
2019-07-20 11:22:29.543 [ome.event.ItemCommandEvent] - Item 'LSSofa_Color' received command 333,35,49
2019-07-20 11:22:29.552 [ome.event.ItemCommandEvent] - Item 'LBWohnSchrank_Color' received command 333,35,49
2019-07-20 11:22:29.554 [nt.ItemStatePredictedEvent] - LSTv_Color predicted to become 17,64,49
2019-07-20 11:22:29.558 [nt.ItemStatePredictedEvent] - LSKueche_Color predicted to become 333,35,49
2019-07-20 11:22:29.573 [vent.ItemStateChangedEvent] - LSTv_Color changed from 198,94,54 to 17,64,49
2019-07-20 11:22:29.589 [vent.ItemStateChangedEvent] - LSKueche_Color changed from 198,94,54 to 333,35,49
2019-07-20 11:22:29.594 [nt.ItemStatePredictedEvent] - LIWohnSofa_Color predicted to become 17,64,49
2019-07-20 11:22:29.598 [vent.ItemStateChangedEvent] - LIWohnSofa_Color changed from 197,100,54 to 17,64,49
2019-07-20 11:22:29.602 [nt.ItemStatePredictedEvent] - LSSofa_Color predicted to become 333,35,49
2019-07-20 11:22:29.605 [vent.ItemStateChangedEvent] - LSSofa_Color changed from 198,94,54 to 333,35,49
2019-07-20 11:22:29.608 [nt.ItemStatePredictedEvent] - LBWohnSchrank_Color predicted to become 333,35,49
2019-07-20 11:22:29.617 [vent.ItemStateChangedEvent] - LBWohnSchrank_Color changed from 197,100,54 to 333,35,49
2019-07-20 11:22:31.382 [vent.ItemStateChangedEvent] - LIWohnSofa_Dimmer changed from 54 to 49
2019-07-20 11:22:31.391 [vent.ItemStateChangedEvent] - LIWohnSofa_Color changed from 17,64,49 to 16,63,49
2019-07-20 11:22:31.479 [vent.ItemStateChangedEvent] - switch_wohnzimmer_5_6fach_UL_kurz changed from ON to OFF
2019-07-20 11:22:31.490 [INFO ] [eclipse.smarthome.model.script.davor] - 0
2019-07-20 11:22:31.496 [ome.event.ItemCommandEvent] - Item 'LSTv_Color' received command 36,75,100
2019-07-20 11:22:31.499 [ome.event.ItemCommandEvent] - Item 'LSKueche_Color' received command 36,75,100
2019-07-20 11:22:31.511 [nt.ItemStatePredictedEvent] - LSTv_Color predicted to become 36,75,100
2019-07-20 11:22:31.517 [INFO ] [lipse.smarthome.model.script.dannach] - 1```
Do I make anything wrong? Does anyone got the same issue? I thought it is a factory issue but all my items are doing the same.
Thanks for any support
Best Felix
