i write a custom binding to display data from a fronius solar system.
I can define a pattern for the state for example:
<channel-type id="pac">
<item-type>Number</item-type>
<label>AC powery</label>
<description>AC power</description>
<state pattern="%d W" readOnly="true"></state>
</channel-type>
In this solution the unit (W) is fix, but the solar system return a unit for each value.
Can i change the pattern at runtime?
Thanks & Greetings
