Static Variables deifinition?
Hello Guys.
If i wanna have some static variables to use around in the logics, with no KNX address but only to use between UI and rules, must they be created in the items file like all other items?
If you want to put something on the sitemap it must be an Item whether or not it is static.
Yes, but if i wanna use some between logics - without having influence on the UI?
You can create a global var or val as described on the Rules wiki page. But those will only be visible to rules within the same file. If you need to share data across rules files you must put the data into an Item. If you don’t want the Item to be on your UI don’t put it into your sitemap.
Thanks - exactly the answer i needed :slight_smile:
