I have setup several Tasmota flashed power plugs. I am reading them via MQTT which is working fine but 1 status is not showing up in the sitemap. Other appliances with the same (code) set-up are showing up.
Below the code that I am using for the washingmachine. You can see that it shows online in Visual Studio Code and in the Paper UI but not in the sitemap.
