The openHAB homepage lists 3 different FritzBox bindings: AVM FRITZ! Binding, Fritz!Box (OH1), Fritzbox TR064 (OH1).
This makes choosing the right binding quite hard, especially for new users.
When I interpret the documentation correctly:
- The AVM FRITZ! Binding is currently under development and will eventually replace the others.
- Until then, the 2 alternate OH1 bindings must be used for such things as “call monitoring” for example
In case that is correct,
- an example to use the OH1 bindings under OH2 would make it easier to get started (at least some links)
- The OH1 deprecation warning box on the top of the page is missing on both OH1 bindings to mark them clearly as deprecated.
