You can configure the poll interval within the Thing, or in a rule, you can send “REFRESH” to the Item.
thanks @5iver !
i tried it with the poll interval which somehow didn’t work for me, but the refresh rule helped.
Is there an update on the Qubino switches not sending physical button status/updates (when pushed/pressed)?
I have two Qubino Flush 2 relays (ZMNHBD firmware 5.0) and the only status change I get is for the “all” Switch button. When physically pressing switch1 or switch2 there is no update send to openhab.
Are there any settings I missed to get this working?
Edit:
Ok, so I have set Q1 and Q2 Basic ON/OFF association group to the controller. And now I get ON/OFF messages for Switch1 and Switch2 when pressing the physical buttons.
I’m a bit confused, isn’t this supposed to work without setting the basic on/off association?
I just bought a few ZMNHSD DIN Rail Dimmer. They are correcty working when commanded through openhab but as reported by several users here, the status is not updated when I turn the light on/off using the physical switch. I did some debugging it would seem that my Qubino is not sending status update top openhab when commanded by the physical switch. Is there a way to correct this or is it a limitation from the Qubino?
I’m running the latest version of OpenHab and snapshot 2.4 for zwave bindings.
EDIT: Problem solved, I made the below changes in the association group of the Qubino and it is now correctly reporting the status to Openhab.
1: Controller update -> change from empty to controller
2: I1 Basic On/off -> added the controller
Gaetan
do you get this also for the SWITCH channel?
I only get updates in the Dimmer Channel
Only for the dimmer. The switch status is indeed not updated.
Tip of the day:
Set param 100 to 9.
Set param 250 to 0. (If available)
Excluse from network and do a unsecure include.
After inclusion unset all associations.
Set lifeline to controller (plain association)
Set Multi-channel Association 5 to controller.
Good luck
for the history: the tip of the day of @RPJacobs (just above) definitely gets it to work (for me: status updates from L2 on a Qubino Flush 1D relay), thanks with 100 votes
