I integrated a Steinel Motion Detector 140-2 via z-wave Binding into my OH3.
Everything works fine, but after some weeks it seems like the motion detector sometimes crashes: sometimes it doesn’t send luminance values anymore, sometimes it switches the light on and even time is set to 28 (seconds to turn off again) the light stays on for ever, even during daytime.
The only way to restart the motion sensor I could find so far is to switch off the fuse it is connected to, but as there are some other devices connected to the same fuse I was wondering if there is a possibility to send a restart command from OH3 to the device?
There is probably something going on that needs investigation, however on the UI page the “Reinitialize device” should probably work as a restart.
