Using Openhabian on Pi.
Installed 2.5M1 because it was recommended and has later ZWave database.
Has never worked. I think it is serial connection.
Added logging. Now the system runs for a few hours and crashed. See log.
It eventually removes everything and shuts itself down.
Once in awhile zwave devices work, but when they do it’s very very slow. Have about 60 devices.
Thanks.
2019-07-23 20:41:43.092 [temChannelLinkRemovedEvent] - Link ‘ML_Hallway_Dimmer1 => zwave:device:f34de27d:node5:switch_dimmer’ has been removed.
2019-07-23 20:41:43.093 [temChannelLinkRemovedEvent] - Link ‘BS_Storage_Sensor => zwave:device:f34de27d:node59:sensor_binary’ has been removed.
2019-07-23 20:41:43.095 [temChannelLinkRemovedEvent] - Link ‘ML_Kitchen_Dimmer2 => zwave:device:f34de27d:node5:switch_dimmer’ has been removed.
2019-07-23 20:41:43.097 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h30 => openweathermap:weather-and-forecast:api:local:forecastHours30#condition-id’ has been removed.
2019-07-23 20:41:43.098 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionIcon => openweathermap:weather-and-forecast:api:local:current#icon’ has been removed.
2019-07-23 20:41:43.100 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId1 => openweathermap:weather-and-forecast:api:local:forecastHours24#condition-id’ has been removed.
2019-07-23 20:41:43.101 [temChannelLinkRemovedEvent] - Link ‘zmMonitor1_Function => zoneminder:monitor:ZoneMinderSample:monitor-1:function’ has been removed.
2019-07-23 20:41:43.103 [temChannelLinkRemovedEvent] - Link ‘MS_Deck_Dimmer => zwave:device:f34de27d:node49:switch_dimmer’ has been removed.
2019-07-23 20:41:43.105 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h51 => openweathermap:weather-and-forecast:api:local:forecastHours51#condition-id’ has been removed.
2019-07-23 20:41:43.106 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temperature => openweathermap:weather-and-forecast:api:local:current#temperature’ has been removed.
2019-07-23 20:41:43.108 [temChannelLinkRemovedEvent] - Link ‘TeslaAutoconditioning => tesla:models:730ca415:autoconditioning’ has been removed.
2019-07-23 20:41:43.109 [temChannelLinkRemovedEvent] - Link ‘BS_Hallway_Alarm_Power => zwave:device:f34de27d:node44:alarm_power’ has been removed.
2019-07-23 20:41:43.111 [temChannelLinkRemovedEvent] - Link ‘ML_Dining_Thermostat_State => zwave:device:f34de27d:node62:thermostat_state1’ has been removed.
2019-07-23 20:41:43.112 [temChannelLinkRemovedEvent] - Link ‘DB_Rear_Living_Flood_Light => zwave:device:f34de27d:node32:switch_binary’ has been removed.
2019-07-23 20:41:43.114 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h72 => openweathermap:weather-and-forecast:api:local:forecastHours72#time-stamp’ has been removed.
2019-07-23 20:41:43.115 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h21 => openweathermap:weather-and-forecast:api:local:forecastHours21#condition’ has been removed.
2019-07-23 20:41:43.117 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h54 => openweathermap:weather-and-forecast:api:local:forecastHours54#temperature’ has been removed.
2019-07-23 20:41:43.119 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Thermostat_Battery_Level => zwave:device:f34de27d:node45:battery-level’ has been removed.
2019-07-23 20:41:43.120 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ObservationTime => openweathermap:weather-and-forecast:api:local:current#time-stamp’ has been removed.
2019-07-23 20:41:43.122 [temChannelLinkRemovedEvent] - Link ‘zmMonitor1_DetailedStatus => zoneminder:monitor:ZoneMinderSample:monitor-1:detailed-status’ has been removed.
2019-07-23 20:41:43.123 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h69 => openweathermap:weather-and-forecast:api:local:forecastHours69#temperature’ has been removed.
2019-07-23 20:41:43.125 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h84 => openweathermap:weather-and-forecast:api:local:forecastHours84#condition-id’ has been removed.
2019-07-23 20:41:43.126 [temChannelLinkRemovedEvent] - Link ‘ML_WindowWall_Lights3 => zwave:device:f34de27d:node22:switch_binary’ has been removed.
2019-07-23 20:41:43.128 [temChannelLinkRemovedEvent] - Link ‘ML_Workout_Audio_Bass => russound:zone:192168020:1:2:bass’ has been removed.
2019-07-23 20:41:43.129 [temChannelLinkRemovedEvent] - Link ‘TeslaSoC => tesla:models:730ca415:soc’ has been removed.
2019-07-23 20:41:43.131 [temChannelLinkRemovedEvent] - Link ‘TeslaTimeToFullCharge => tesla:models:730ca415:timetofullcharge’ has been removed.
2019-07-23 20:41:43.132 [temChannelLinkRemovedEvent] - Link ‘BS_WineCellar_Switch1 => zwave:device:f34de27d:node30:switch_binary1’ has been removed.
2019-07-23 20:41:43.134 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h36 => openweathermap:weather-and-forecast:api:local:forecastHours36#condition-id’ has been removed.
2019-07-23 20:41:43.135 [temChannelLinkRemovedEvent] - Link ‘DB_RearTerrace_Dimmer1 => zwave:device:f34de27d:node8:switch_dimmer’ has been removed.
2019-07-23 20:41:43.137 [temChannelLinkRemovedEvent] - Link ‘zmMonitor1_CaptureState => zoneminder:monitor:ZoneMinderSample:monitor-1:capture-daemon’ has been removed.
2019-07-23 20:41:43.138 [temChannelLinkRemovedEvent] - Link ‘ML_Staircase_Ceiling_Lights => zwave:device:f34de27d:node36:switch_dimmer’ has been removed.
2019-07-23 20:41:43.140 [temChannelLinkRemovedEvent] - Link ‘zmMonitor1_Enabled => zoneminder:monitor:ZoneMinderSample:monitor-1:enabled’ has been removed.
2019-07-23 20:41:43.141 [temChannelLinkRemovedEvent] - Link ‘ML_Pantry_Switch1 => zwave:device:f34de27d:node67:switch_binary’ has been removed.
2019-07-23 20:41:43.143 [temChannelLinkRemovedEvent] - Link ‘ML_LivingRoom_Audio_Mute => russound:zone:192168020:1:1:mute’ has been removed.
2019-07-23 20:41:43.144 [temChannelLinkRemovedEvent] - Link ‘Moon_Elevation => astro:moon:home:position#elevation’ has been removed.
2019-07-23 20:41:43.146 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h66 => openweathermap:weather-and-forecast:api:local:forecastHours66#condition’ has been removed.
2019-07-23 20:41:43.147 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h78 => openweathermap:weather-and-forecast:api:local:forecastHours78#condition-id’ has been removed.
2019-07-23 20:41:43.149 [temChannelLinkRemovedEvent] - Link ‘ML_Hallway_Dimmer2 => zwave:device:f34de27d:node7:switch_dimmer’ has been removed.
2019-07-23 20:41:43.150 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h69 => openweathermap:weather-and-forecast:api:local:forecastHours69#time-stamp’ has been removed.
2019-07-23 20:41:43.152 [temChannelLinkRemovedEvent] - Link ‘BS_Hallway_Trains_Dimmer1 => zwave:device:f34de27d:node41:switch_dimmer’ has been removed.
2019-07-23 20:41:43.153 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h45 => openweathermap:weather-and-forecast:api:local:forecastHours45#condition’ has been removed.
2019-07-23 20:41:43.155 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h78 => openweathermap:weather-and-forecast:api:local:forecastHours78#condition’ has been removed.
2019-07-23 20:41:43.156 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Thermostat_Humidity => zwave:device:f34de27d:node45:sensor_relhumidity2’ has been removed.
2019-07-23 20:41:43.158 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h75 => openweathermap:weather-and-forecast:api:local:forecastHours75#condition-id’ has been removed.
2019-07-23 20:41:43.159 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h87 => openweathermap:weather-and-forecast:api:local:forecastHours87#condition’ has been removed.
2019-07-23 20:41:43.161 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId => openweathermap:weather-and-forecast:api:local:current#condition-id’ has been removed.
2019-07-23 20:41:43.162 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h60 => openweathermap:weather-and-forecast:api:local:forecastHours60#temperature’ has been removed.
2019-07-23 20:41:43.164 [temChannelLinkRemovedEvent] - Link ‘zmMonitor1_FrameState => zoneminder:monitor:ZoneMinderSample:monitor-1:frame-daemon’ has been removed.
2019-07-23 20:41:43.165 [temChannelLinkRemovedEvent] - Link ‘CL_CedarCloset_Alarm => zwave:device:f34de27d:node26:alarm_burglar2’ has been removed.
2019-07-23 20:41:43.167 [temChannelLinkRemovedEvent] - Link ‘DB_Rear_High_Flood_Light => zwave:device:f34de27d:node33:switch_binary’ has been removed.
2019-07-23 20:41:43.168 [temChannelLinkRemovedEvent] - Link ‘BS_Storage_Alarm => zwave:device:f34de27d:node59:alarm_burglar2’ has been removed.
2019-07-23 20:41:43.170 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Audio_Source => russound:zone:192168020:1:5:source’ has been removed.
2019-07-23 20:41:43.171 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h87 => openweathermap:weather-and-forecast:api:local:forecastHours87#temperature’ has been removed.
2019-07-23 20:41:43.173 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition3 => openweathermap:weather-and-forecast:api:local:forecastHours72#condition’ has been removed.
2019-07-23 20:41:43.174 [temChannelLinkRemovedEvent] - Link ‘ML_Garage_Motion1 => zwave:device:f34de27d:node14:alarm_motion2’ has been removed.
2019-07-23 20:41:43.176 [temChannelLinkRemovedEvent] - Link ‘CL_CedarCloset_Switch1 => zwave:device:f34de27d:node26:switch_binary’ has been removed.
2019-07-23 20:41:43.177 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Sensor_Enable => zwave:device:f34de27d:node58:config_decimal_param6’ has been removed.
2019-07-23 20:41:43.179 [temChannelLinkRemovedEvent] - Link ‘ML_Kitchen_Dimmer1 => zwave:device:f34de27d:node63:switch_dimmer’ has been removed.
2019-07-23 20:41:43.180 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h63 => openweathermap:weather-and-forecast:api:local:forecastHours63#condition-id’ has been removed.
2019-07-23 20:41:43.182 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h72 => openweathermap:weather-and-forecast:api:local:forecastHours72#temperature’ has been removed.
2019-07-23 20:41:43.183 [temChannelLinkRemovedEvent] - Link ‘BS_WineCellar_Sensor_Enable => zwave:device:f34de27d:node30:config_decimal_param6’ has been removed.
2019-07-23 20:41:43.185 [temChannelLinkRemovedEvent] - Link ‘ML_PowderRoom_Alarm => zwave:device:f34de27d:node61:alarm_motion2’ has been removed.
2019-07-23 20:41:43.186 [temChannelLinkRemovedEvent] - Link ‘TeslaSpeed => tesla:models:730ca415:speed’ has been removed.
2019-07-23 20:41:43.188 [temChannelLinkRemovedEvent] - Link ‘TeslaGPSStamp => tesla:models:730ca415:gpstimestamp’ has been removed.
2019-07-23 20:41:43.189 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h12 => openweathermap:weather-and-forecast:api:local:forecastHours12#time-stamp’ has been removed.
2019-07-23 20:41:43.191 [temChannelLinkRemovedEvent] - Link ‘CL_GuestSuiteLounge_Audio_Bass => russound:zone:192168020:1:4:bass’ has been removed.
2019-07-23 20:41:43.196 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Thermostat_Fanstate => zwave:device:f34de27d:node45:thermostat_fanstate’ has been removed.
2019-07-23 20:41:43.197 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Station_Name => openweathermap:weather-and-forecast:api:local:station#name’ has been removed.
2019-07-23 20:41:43.198 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Switch1 => zwave:device:f34de27d:node58:switch_binary1’ has been removed.
2019-07-23 20:41:44.168 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2019-07-23 20:41:44.208 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[ESH-httpClient-common]@183abdd{STOPPING,10<=10<=40,i=0,q=5}[org.eclipse.jetty.util.thread.TryExecutor$$Lambda$320/996680@60f424] Couldn’t stop Thread[ESH-httpClient-common-103,5,main]
2019-07-23 20:41:44.210 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[ESH-httpClient-common]@183abdd{STOPPING,10<=10<=40,i=0,q=5}[org.eclipse.jetty.util.thread.TryExecutor$$Lambda$320/996680@60f424] Couldn’t stop Thread[ESH-httpClient-common-102,5,main]
2019-07-23 20:41:44.229 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2019-07-23 20:41:44.244 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2019-07-23 20:41:44.277 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-07-23 20:41:42.771 [temChannelLinkRemovedEvent] - Link ‘DB_RearTerrace_LED_Strip1_Color_Temp => zwave:device:f34de27d:node69:color_temperature’ has been removed.
2019-07-23 20:41:42.773 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h39 => openweathermap:weather-and-forecast:api:local:forecastHours39#condition’ has been removed.
2019-07-23 20:41:42.775 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h96 => openweathermap:weather-and-forecast:api:local:forecastHours96#condition’ has been removed.
2019-07-23 20:41:42.777 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp3 => openweathermap:weather-and-forecast:api:local:forecastHours72#temperature’ has been removed.
2019-07-23 20:41:42.780 [temChannelLinkRemovedEvent] - Link ‘DB_RearTerrace_Audio_Bass => russound:zone:192168020:1:6:bass’ has been removed.
2019-07-23 20:41:42.782 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition => openweathermap:weather-and-forecast:api:local:current#condition’ has been removed.
2019-07-23 20:41:42.784 [temChannelLinkRemovedEvent] - Link ‘DF_Outdoor_Front_Lights1 => zwave:device:f34de27d:node23:switch_binary’ has been removed.
2019-07-23 20:41:42.786 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h81 => openweathermap:weather-and-forecast:api:local:forecastHours81#condition-id’ has been removed.
2019-07-23 20:41:42.788 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Forecast_Time2 => openweathermap:weather-and-forecast:api:local:forecastHours48#time-stamp’ has been removed.
2019-07-23 20:41:42.790 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h87 => openweathermap:weather-and-forecast:api:local:forecastHours87#condition-id’ has been removed.
2019-07-23 20:41:42.800 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h3 => openweathermap:weather-and-forecast:api:local:forecastHours03#temperature’ has been removed.
2019-07-23 20:41:42.802 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Hall_Switch => zwave:device:f34de27d:node51:switch_binary’ has been removed.
2019-07-23 20:41:42.805 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Thermostat_Fanmode => zwave:device:f34de27d:node45:thermostat_fanmode’ has been removed.
2019-07-23 20:41:42.807 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Audio_Source => russound:zone:192168020:1:3:source’ has been removed.
2019-07-23 20:41:42.809 [temChannelLinkRemovedEvent] - Link ‘ML_LivingRoom_Audio_Loudness => russound:zone:192168020:1:1:loudness’ has been removed.
2019-07-23 20:41:42.811 [temChannelLinkRemovedEvent] - Link ‘DF_Monitor5 => zoneminder:monitor:52b9a5f2:monitor-5:online’ has been removed.
2019-07-23 20:41:42.813 [temChannelLinkRemovedEvent] - Link ‘TeslaOutsideTemperature => tesla:models:730ca415:outsidetemp’ has been removed.
2019-07-23 20:41:42.818 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Thermostat_State => zwave:device:f34de27d:node45:thermostat_state’ has been removed.
2019-07-23 20:41:42.835 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h45 => openweathermap:weather-and-forecast:api:local:forecastHours45#time-stamp’ has been removed.
2019-07-23 20:41:42.837 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h45 => openweathermap:weather-and-forecast:api:local:forecastHours45#temperature’ has been removed.
2019-07-23 20:41:42.839 [temChannelLinkRemovedEvent] - Link ‘ML_LivingRoom_Thermostat_Setpoint_Cooling => zwave:device:f34de27d:node53:thermostat_setpoint_cooling’ has been removed.
2019-07-23 20:41:42.841 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h69 => openweathermap:weather-and-forecast:api:local:forecastHours69#condition-id’ has been removed.
2019-07-23 20:41:42.844 [temChannelLinkRemovedEvent] - Link ‘BS_Hallway_Alarm => zwave:device:f34de27d:node44:alarm_burglar’ has been removed.
2019-07-23 20:41:42.846 [temChannelLinkRemovedEvent] - Link ‘BS_Storage_Switch => zwave:device:f34de27d:node59:switch_binary’ has been removed.
2019-07-23 20:41:42.847 [temChannelLinkRemovedEvent] - Link ‘TeslaBatteryCurrent => tesla:models:730ca415:batterycurrent’ has been removed.
2019-07-23 20:41:42.849 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h87 => openweathermap:weather-and-forecast:api:local:forecastHours87#time-stamp’ has been removed.
2019-07-23 20:41:42.851 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition2 => openweathermap:weather-and-forecast:api:local:forecastHours48#condition’ has been removed.
2019-07-23 20:41:42.859 [temChannelLinkRemovedEvent] - Link ‘zmServer_CpuLoad => zoneminder:server:52b9a5f2:cpu-load’ has been removed.
2019-07-23 20:41:42.861 [temChannelLinkRemovedEvent] - Link ‘TeslaBatteryLevel => tesla:models:730ca415:batterylevel’ has been removed.
2019-07-23 20:41:42.864 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h12 => openweathermap:weather-and-forecast:api:local:forecastHours12#condition’ has been removed.
2019-07-23 20:41:42.866 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Audio_Treble => russound:zone:192168020:1:3:treble’ has been removed.
2019-07-23 20:41:42.868 [temChannelLinkRemovedEvent] - Link ‘ML_LivingRoom_Audio_Source => russound:zone:192168020:1:1:source’ has been removed.
2019-07-23 20:41:42.870 [temChannelLinkRemovedEvent] - Link ‘ML_Dining_Thermostat_Humidity => zwave:device:f34de27d:node62:sensor_relhumidity2’ has been removed.
2019-07-23 20:41:42.872 [temChannelLinkRemovedEvent] - Link ‘ML_Garage_sensor_binary => zwave:device:f34de27d:node14:sensor_binary’ has been removed.
2019-07-23 20:41:42.874 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h54 => openweathermap:weather-and-forecast:api:local:forecastHours54#condition-id’ has been removed.
2019-07-23 20:41:42.877 [temChannelLinkRemovedEvent] - Link ‘CL_Hallway_Thermostat_Fanmode => zwave:device:f34de27d:node54:thermostat_fanmode’ has been removed.
2019-07-23 20:41:42.879 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h54 => openweathermap:weather-and-forecast:api:local:forecastHours54#condition’ has been removed.
2019-07-23 20:41:42.881 [temChannelLinkRemovedEvent] - Link ‘ML_PowderRoom_Switch1 => zwave:device:f34de27d:node61:switch_binary1’ has been removed.
2019-07-23 20:41:42.883 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h33 => openweathermap:weather-and-forecast:api:local:forecastHours33#condition-id’ has been removed.
2019-07-23 20:41:42.886 [temChannelLinkRemovedEvent] - Link ‘ML_Dining_Thermostat_Temperature => zwave:device:f34de27d:node62:sensor_temperature’ has been removed.
2019-07-23 20:41:42.888 [temChannelLinkRemovedEvent] - Link ‘MS_Bathroom_Alarm2 => zwave:device:f34de27d:node52:alarm_burglar2’ has been removed.
2019-07-23 20:41:42.891 [temChannelLinkRemovedEvent] - Link ‘TeslaScheduledChargingStart => tesla:models:730ca415:scheduledchargingstart’ has been removed.
2019-07-23 20:41:42.893 [temChannelLinkRemovedEvent] - Link ‘TeslaInsideTemperature => tesla:models:730ca415:insidetemp’ has been removed.
2019-07-23 20:41:42.895 [temChannelLinkRemovedEvent] - Link ‘zmMonitor1_EventState => zoneminder:monitor:ZoneMinderSample:monitor-1:alarm’ has been removed.
2019-07-23 20:41:42.898 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Audio_Bass => russound:zone:192168020:1:3:bass’ has been removed.
2019-07-23 20:41:42.902 [temChannelLinkRemovedEvent] - Link ‘Current_date_time => ntp:ntp:local:dateTime’ has been removed.
2019-07-23 20:41:42.905 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h45 => openweathermap:weather-and-forecast:api:local:forecastHours45#condition-id’ has been removed.
2019-07-23 20:41:42.908 [temChannelLinkRemovedEvent] - Link ‘ML_Pantry_Alarm => zwave:device:f34de27d:node67:alarm_burglar’ has been removed.
2019-07-23 20:41:42.910 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h24 => openweathermap:weather-and-forecast:api:local:forecastHours24#condition’ has been removed.
2019-07-23 20:41:42.913 [temChannelLinkRemovedEvent] - Link ‘MS_Lounge_Dimmer1 => zwave:device:f34de27d:node48:switch_dimmer’ has been removed.
2019-07-23 20:41:42.915 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h57 => openweathermap:weather-and-forecast:api:local:forecastHours57#condition’ has been removed.
2019-07-23 20:41:42.917 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h96 => openweathermap:weather-and-forecast:api:local:forecastHours96#condition-id’ has been removed.
2019-07-23 20:41:42.919 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h33 => openweathermap:weather-and-forecast:api:local:forecastHours33#time-stamp’ has been removed.
2019-07-23 20:41:42.922 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h27 => openweathermap:weather-and-forecast:api:local:forecastHours27#condition’ has been removed.
2019-07-23 20:41:42.924 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h96 => openweathermap:weather-and-forecast:api:local:forecastHours96#temperature’ has been removed.
2019-07-23 20:41:42.927 [temChannelLinkRemovedEvent] - Link ‘ML_Garage_Alarm => zwave:device:f34de27d:node14:alarm_burglar2’ has been removed.
2019-07-23 20:41:42.929 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h81 => openweathermap:weather-and-forecast:api:local:forecastHours81#temperature’ has been removed.
2019-07-23 20:41:42.933 [temChannelLinkRemovedEvent] - Link ‘BS_Storage_Sensor_Enable => zwave:device:f34de27d:node59:config_decimal_param6’ has been removed.
2019-07-23 20:41:42.935 [temChannelLinkRemovedEvent] - Link ‘CL_GuestSuiteLounge_Audio_Loudness => russound:zone:192168020:1:4:loudness’ has been removed.
2019-07-23 20:41:42.938 [temChannelLinkRemovedEvent] - Link ‘CL_LaundryRoom_Lights1 => zwave:device:f34de27d:node25:switch_binary’ has been removed.
2019-07-23 20:41:42.940 [temChannelLinkRemovedEvent] - Link ‘Unknown_Switch => zwave:device:f34de27d:node27:switch_binary’ has been removed.
2019-07-23 20:41:42.942 [temChannelLinkRemovedEvent] - Link ‘ML_Hallway_Sconce_Switch => zwave:device:f34de27d:node46:switch_binary’ has been removed.
2019-07-23 20:41:42.945 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h30 => openweathermap:weather-and-forecast:api:local:forecastHours30#condition’ has been removed.
2019-07-23 20:41:42.947 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h60 => openweathermap:weather-and-forecast:api:local:forecastHours60#condition-id’ has been removed.
2019-07-23 20:41:42.949 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h66 => openweathermap:weather-and-forecast:api:local:forecastHours66#time-stamp’ has been removed.
2019-07-23 20:41:42.952 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Switch => zwave:device:f34de27d:node58:switch_binary’ has been removed.
2019-07-23 20:41:42.954 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h57 => openweathermap:weather-and-forecast:api:local:forecastHours57#condition-id’ has been removed.
2019-07-23 20:41:42.956 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Audio_Volume => russound:zone:192168020:1:3:volume’ has been removed.
2019-07-23 20:41:42.959 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h15 => openweathermap:weather-and-forecast:api:local:forecastHours15#condition’ has been removed.
2019-07-23 20:41:42.961 [temChannelLinkRemovedEvent] - Link ‘TeslaLatitude => tesla:models:730ca415:latitude’ has been removed.
2019-07-23 20:41:42.964 [temChannelLinkRemovedEvent] - Link ‘DB_RearTerrace_LED_Strip1_Dimmer => zwave:device:f34de27d:node69:switch_dimmer’ has been removed.
2019-07-23 20:41:42.966 [temChannelLinkRemovedEvent] - Link ‘zmServer_DiskUsage => zoneminder:server:52b9a5f2:disk-usage’ has been removed.
2019-07-23 20:41:42.969 [temChannelLinkRemovedEvent] - Link ‘TeslaPower => tesla:models:730ca415:power’ has been removed.
2019-07-23 20:41:42.971 [temChannelLinkRemovedEvent] - Link ‘ML_LivingRoom_Thermostat_Fanstate => zwave:device:f34de27d:node53:thermostat_fanstate’ has been removed.
2019-07-23 20:41:42.974 [temChannelLinkRemovedEvent] - Link ‘BS_Hallway_Motion => zwave:device:f34de27d:node44:switch_binary’ has been removed.
2019-07-23 20:41:42.976 [temChannelLinkRemovedEvent] - Link ‘ML_LivingRoom_Audio_Treble => russound:zone:192168020:1:1:treble’ has been removed.
2019-07-23 20:41:42.979 [temChannelLinkRemovedEvent] - Link ‘ML_Pantry_Alarm2 => zwave:device:f34de27d:node67:alarm_burglar2’ has been removed.
2019-07-23 20:41:42.981 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h33 => openweathermap:weather-and-forecast:api:local:forecastHours33#temperature’ has been removed.
2019-07-23 20:41:42.983 [temChannelLinkRemovedEvent] - Link ‘Sun_Azimuth => astro:sun:home:position#azimuth’ has been removed.
2019-07-23 20:41:42.985 [temChannelLinkRemovedEvent] - Link ‘CL_Hallway_Thermostat_State => zwave:device:f34de27d:node54:thermostat_state’ has been removed.
2019-07-23 20:41:42.987 [temChannelLinkRemovedEvent] - Link ‘DB_RearTerrace_Audio_Source => russound:zone:192168020:1:6:source’ has been removed.
2019-07-23 20:41:42.990 [temChannelLinkRemovedEvent] - Link ‘ML_MudRoom_Switch => zwave:device:f34de27d:node67:switch_binary’ has been removed.
2019-07-23 20:41:42.992 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h15 => openweathermap:weather-and-forecast:api:local:forecastHours15#condition-id’ has been removed.
2019-07-23 20:41:42.994 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h6 => openweathermap:weather-and-forecast:api:local:forecastHours06#time-stamp’ has been removed.
2019-07-23 20:41:42.997 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h81 => openweathermap:weather-and-forecast:api:local:forecastHours81#condition’ has been removed.
2019-07-23 20:41:42.999 [temChannelLinkRemovedEvent] - Link ‘ML_Dining_Thermostat_Mode => zwave:device:f34de27d:node62:thermostat_mode’ has been removed.
2019-07-23 20:41:43.002 [temChannelLinkRemovedEvent] - Link ‘DB_RearTerrace_Audio_Treble => russound:zone:192168020:1:6:treble’ has been removed.
2019-07-23 20:41:43.004 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Audio_Mute => russound:zone:192168020:1:3:mute’ has been removed.
2019-07-23 20:41:43.006 [temChannelLinkRemovedEvent] - Link ‘ML_Workout_Audio_Treble => russound:zone:192168020:1:2:treble’ has been removed.
2019-07-23 20:41:43.008 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Audio_Loudness => russound:zone:192168020:1:5:loudness’ has been removed.
2019-07-23 20:41:43.011 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h51 => openweathermap:weather-and-forecast:api:local:forecastHours51#time-stamp’ has been removed.
2019-07-23 20:41:43.013 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Audio_Loudness => russound:zone:192168020:1:3:loudness’ has been removed.
2019-07-23 20:41:43.015 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h84 => openweathermap:weather-and-forecast:api:local:forecastHours84#condition’ has been removed.
2019-07-23 20:41:43.017 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h12 => openweathermap:weather-and-forecast:api:local:forecastHours12#temperature’ has been removed.
2019-07-23 20:41:43.020 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h84 => openweathermap:weather-and-forecast:api:local:forecastHours84#temperature’ has been removed.
2019-07-23 20:41:43.022 [temChannelLinkRemovedEvent] - Link ‘BS_MainRoom_Switch1 => zwave:device:f34de27d:node40:switch_binary’ has been removed.
2019-07-23 20:41:43.024 [temChannelLinkRemovedEvent] - Link ‘TeslaEventstamp => tesla:models:730ca415:eventstamp’ has been removed.
2019-07-23 20:41:43.026 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp0 => openweathermap:weather-and-forecast:api:local:forecastHours03#temperature’ has been removed.
2019-07-23 20:41:43.028 [temChannelLinkRemovedEvent] - Link ‘CL_GuestSuiteLounge_Audio_Balance => russound:zone:192168020:1:4:balance’ has been removed.
2019-07-23 20:41:43.030 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Outlets => zwave:device:f34de27d:node50:switch_binary’ has been removed.
2019-07-23 20:41:43.032 [temChannelLinkRemovedEvent] - Link ‘MS_Closet_Alarm2 => zwave:device:f34de27d:node56:alarm_burglar2’ has been removed.
2019-07-23 20:41:43.035 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition1 => openweathermap:weather-and-forecast:api:local:forecastHours24#condition’ has been removed.
2019-07-23 20:41:43.037 [temChannelLinkRemovedEvent] - Link ‘ML_Dining_Thermostat_Battery_Level => zwave:device:f34de27d:node62:battery-level1’ has been removed.
2019-07-23 20:41:43.040 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h63 => openweathermap:weather-and-forecast:api:local:forecastHours63#time-stamp’ has been removed.
2019-07-23 20:41:43.043 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h3 => openweathermap:weather-and-forecast:api:local:forecastHours03#time-stamp’ has been removed.
2019-07-23 20:41:43.046 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h75 => openweathermap:weather-and-forecast:api:local:forecastHours75#condition’ has been removed.
2019-07-23 20:41:43.049 [temChannelLinkRemovedEvent] - Link ‘TeslaChargeRate => tesla:models:730ca415:chargerate’ has been removed.
2019-07-23 20:41:43.051 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Condition_h9 => openweathermap:weather-and-forecast:api:local:forecastHours09#condition’ has been removed.
2019-07-23 20:41:43.054 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h27 => openweathermap:weather-and-forecast:api:local:forecastHours27#temperature’ has been removed.
2019-07-23 20:41:43.056 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_ConditionId_h42 => openweathermap:weather-and-forecast:api:local:forecastHours42#condition-id’ has been removed.
2019-07-23 20:41:43.059 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_DateTime_h9 => openweathermap:weather-and-forecast:api:local:forecastHours09#time-stamp’ has been removed.
2019-07-23 20:41:43.061 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h93 => openweathermap:weather-and-forecast:api:local:forecastHours93#temperature’ has been removed.
2019-07-23 20:41:43.064 [temChannelLinkRemovedEvent] - Link ‘CL_Hallway_Thermostat_Humidity => zwave:device:f34de27d:node54:sensor_relhumidity2’ has been removed.
2019-07-23 20:41:43.066 [temChannelLinkRemovedEvent] - Link ‘CL_GuestSuiteLounge_Audio_Source => russound:zone:192168020:1:4:source’ has been removed.
2019-07-23 20:41:43.069 [temChannelLinkRemovedEvent] - Link ‘ML_LivingRoom_Thermostat_Battery_Level => zwave:device:f34de27d:node53:battery-level’ has been removed.
2019-07-23 20:41:43.071 [temChannelLinkRemovedEvent] - Link ‘MS_Bathroom_Alarm => zwave:device:f34de27d:node52:alarm_burglar’ has been removed.
2019-07-23 20:41:43.074 [temChannelLinkRemovedEvent] - Link ‘Weather_OWM_Temp_h63 => openweathermap:weather-and-forecast:api:local:forecastHours63#temperature’ has been removed.
2019-07-23 20:41:43.076 [temChannelLinkRemovedEvent] - Link ‘ML_Hallway_FrontDoor_Lights => zwave:device:f34de27d:node24:switch_dimmer’ has been removed.
2019-07-23 20:41:43.078 [temChannelLinkRemovedEvent] - Link ‘CL_Hallway_Thermostat_Setpoint_Heating => zwave:device:f34de27d:node54:thermostat_setpoint_heating’ has been removed.
2019-07-23 20:41:43.081 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Audio_Volume => russound:zone:192168020:1:5:volume’ has been removed.
2019-07-23 20:41:43.083 [temChannelLinkRemovedEvent] - Link ‘Sunrise_Time => astro:sun:home:rise#start’ has been removed.
2019-07-23 20:41:43.086 [temChannelLinkRemovedEvent] - Link ‘ML_Dining_Thermostat_Fanmode => zwave:device:f34de27d:node62:thermostat_fanmode1’ has been removed.
2019-07-23 20:41:43.088 [temChannelLinkRemovedEvent] - Link ‘BS_Shop_Alarm => zwave:device:f34de27d:node58:alarm_burglar2’ has been removed.
2019-07-23 20:41:43.090 [temChannelLinkRemovedEvent] - Link ‘MS_Bedroom_Thermostat_Temperature => zwave:device:f34de27d:node45:sensor_temperature’ has been removed.
