at first i thought that the issue is gone. However in the last few weeks a lot of button presses seemed to be lost from my point of view. Initially i thought this has to do with the horrible RF scenario arround my apartment (sometimes the dimmer switch blinks red). However i just tried it in my office and as you cann see a few button presses are completely lost.
This was not the case with 2.4.
I made a video so that you can see my issue.
In this video you can see that the second and the 5th/6th/7th pressed is lost.
Maybe this is a really dumb question, however i have to ask.
Why was there a change in the first place? What features/functionallity has been added to cause this issues in the first place? From my experience there is no new functionallity exposed to the end user.
@cweitkamp: I got in mind, that you don’t any dimmer switches from you? Maybe i could purchase one for this case?
If you need any more information or logs, i am gladly provide them.
What is your sensorPollingInterval? Default (500ms)? Or different one?
It would be nice to repeat your test and observe the dimmer_switch_event together with the dimmer_switch state channel. May I ask you to do that?
The dimmer_switch_event will be filtered by a check if the “lastupdated” timestamp is between now minus 3 seconds and now. The dimmer_switch channel will be updated every time. The reason is that we want to avoid dispatching events if “lastupdated” is older than now minus 3 seconds (e.g. during restarts).
That is not correct. I have a Dimmer switch and a Smart button. I do not own a Tap switch. But thanks for offering to provide devices for testing.
Over the course of yesterday and today i ran a dozen times through the apartment and clicked every dimmer switch like a maniac. So far i saw only one or two missed button presses. These few missing presses could be explained by not pressing firmly enough.
So it looks like the declaration of the the dimmer_switch state fixes the issue – from my current experience. That could also explain why nobody else experience the issue.
Before the declaration of the item i was just using the “Channel triggered” event like that:
rule "Beleuchtung: Kueche Philips Hue Dimmer Switch wurde betätigt."
Channel "hue:0820:00178827902c:Zigbee_Kueche_Fernbedienung:dimmer_switch_event" triggered
switch(receivedEvent.getEvent()) {
Today i also tried to use my Ikea Tradfri Switch, which was also not working reliable before. After creating the dimmer_switch item for the DECONZ binding the switch worked like a charm.
Number Zigbee_Flur_Tradfri_Schalter_Status "Flur Status [%.1f]" { channel="deconz:switch:bridge:Zigbee_Flur_Tradfri_Schalter:button" }
rule "Beleuchtung: Flur Tradfri Switch wurde betätigt."
Channel "deconz:switch:bridge:Zigbee_Flur_Tradfri_Schalter:buttonevent" triggered
So i got the impression that this isn’t related to the hue binding. I think that could be an issue with the Channel triggered Event if the corresponding item is not created.
@regnets dont know how to prove or disprove your theory, but adding an item helped me also. I did it because of.this thread. Seems like my dimmer is more responsive now. I hadnt used the dimmer long press much because it was hit or miss now it seems to have improved.
Ok maybe this was just the placebo effect. I still think my dimmer switches are more responsive, however yesterday evening is needed to press at least 5 or 6 times before a button press was recognized by openhab.
Does anybody know how to troubleshoot these issues?
I will go post over on Github also. I am now getting this error for my rule.
Only thing I changed was update from 2.5.0 to the 2.5.1 and now 2.5.2. Not sure the versions are fully correct but basicly second upgrade after the stable release. I now get this error on a rule that was working previously.
2020-02-21 07:32:34.497 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'FFAgent Button pressed': An error occurred during the script execution:
Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_plus(java.lang.Object,java.lang.String) on instance: null
Doing more debug now. I will post what I find.
SO weird!!! I restarted and cleaned the cache and now it is working. I know I did this the other day after the upgrade. I am not sure exactly when the remote broke as I have not been using this feature frequently.
Just to rule it out as a potential cause: did you check the ZigBee channel used? Does it interfere with some very busy 2.4 GHz WiFi channels? If so, try finding a channel that is not as busy. It can easily be changed in the official Hue App.
You never know… ;o)
Thanks for the idea, this is something i already did in the first place. I am on a zigbee channel with not too much of traffic, however i am living in a city so there a few access points arround me.
