I set up a Conbee2 USB Stick and it´s working fine, unfortunately only the gateway is discovered by PaperUI but no (Xiaomi) sensors. So I tried to install the Deconz binding, but now I only get this error in logvoewer:
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-deconz': Error:
Resource mvn:org.openhab.binding/org.openhab.binding.deconz/2.4.0 does not contain a manifest
This message is infinitely repeating, how can I stop it? And how to install the deconz binding? I guees I need it to implement my ZigBee sensors.
If your not familiar with adding a binding via jar file it should be placed in usr/share/openhab2/addons after placing the jar file restart OH (sudo systemctl restart openhab2) and watch the logs to see if the binding gets installed.
Clean the cache again and reboot instead of restarting the system. There have been times I needed to reboot several times before everything would come together and start working.
