Hi, what is wrong with the below?
Here’s the scenario:
The KNX weatherstation frequently sends Latitude and Longitude. I want to use it to do some calculations relevant for sun positions and so on…
items:
Number Location_Northern_Latitude “Location Northern Latitude” (All,gSQL) { knx=“<(60)1/2/2” }
Number Location_Eastern_Longitude “Location Eastern Longitude” (All,gSQL) { knx=“<(60)1/2/1” }
Number Sun_Height “Sonnenhöhe” (All,gSQL)
Number Sun_Sun_Azimut “Azimut Sonne” (All,gSQL)
Switch Sun_Dawn_Solar (All,gSQL)
Switch Sun_Dawn_Civil (All,gSQL)
Switch Sun_Dawn_Nautical (All,gSQL)
Switch Sun_Dawn_Astronomical (All,gSQL)
In the database, all tables except Location_Northern_Latitude and Location_Eastern_Longitude are empty.
sun.rules:
import org.openhab.core.library.types.*
import java.lang.Math
// Constants
var Number K = 0.017453
// Change this reflecting your destination
var Number latitude = Location_Northern_Latitude.state as DecimalType
var Number longitude = Location_Eastern_Longitude.state as Decimal Type
rule "Set Sun and Dawn States"
Time cron "0 0/5 * * * ?"
var Number tageszahl
var Number deklination
var Number zeitgleichung
var Number stundenwinkel
var Number x
var Number y
var Number sonnenhoehe
var Number azimut
var month = now.getMonthOfYear
var day = now.getDayOfMonth
var hour = now.getHourOfDay
var minute = now.getMinuteOfHour
// Source: http://www.jgiesen.de/SME/tk/index.htm
tageszahl = (month - 1) * 30 + day + hour / 24
deklination = -23.45 * Math::cos((K * 360 * (tageszahl + 10) / 365).doubleValue)
zeitgleichung = 60.0 * (-0.171 * Math::sin((0.0337*tageszahl+0.465).doubleValue) - 0.1299 * Math::sin((0.01787*tageszahl-0.168).doubleValue))
stundenwinkel = 15.0 * (hour.doubleValue + (minute.doubleValue/60.0) - (15.0-longitude)/15.0 - 12.0 + zeitgleichung/60.0)
x = Math::sin((K * latitude).doubleValue()) * Math::sin((K * deklination).doubleValue()) + Math::cos((K * latitude).doubleValue()) * Math::cos((K * deklination).doubleValue()) * Math::cos((K * stundenwinkel).doubleValue())
y = - (Math::sin((K*latitude).doubleValue) * x - Math::sin((K*deklination).doubleValue)) / (Math::cos((K*latitude).doubleValue) * Math::sin(Math::acos(x.doubleValue)))
sonnenhoehe = Math::asin(x.doubleValue) / K
var break = hour.doubleValue + (minute.doubleValue/60.0) <= 12.0 + (15.0-longitude)/15.0 - zeitgleichung/60.0
if (break) {
azimut = Math::acos(y.doubleValue) / K
} else {
azimut = 360.0 - Math::acos(y.doubleValue) / K
logDebug("Sun.rules", "month: " + month)
logDebug("Sun.rules", "day: " + day)
logDebug("Sun.rules", "hour: " + hour)
logDebug("Sun.rules", "minute: " + minute)
logDebug("Sun.rules", "tageszahl: " + tageszahl)
logDebug("Sun.rules", "deklination: " + deklination)
logDebug("Sun.rules", "zeitgleichung: " + zeitgleichung)
logDebug("Sun.rules", "stundenwinkel: " + stundenwinkel)
logDebug("Sun.rules", "x: " + x)
logDebug("Sun.rules", "y: " + y)
logDebug("Sun.rules", "sonnenhoehe: " + sonnenhoehe)
logDebug("Sun.rules", "azimut: " + azimut)
logDebug("Sun.rules", "Calculated new SunHeight angle '" + sonnenhoehe + "°'")
logDebug("Sun.rules", "Calculated new Azimut angle '" + sonnenhoehe + "°'")
// Send all calculations to the event bus
Sun_Height.postUpdate(sonnenhoehe)
Sun_Azimut.postUpdate(azimut)
Sun_Dawn_Solar.postUpdate( if (sonnenhoehe < 0) ON else OFF )
postUpdate(Sun_Dawn_Civil, if((sonnenhoehe < 0) && (sonnenhoehe >= -6) && (hour < 12)) {ON} else {OFF})
postUpdate(Sun_Dawn_Nautical, if((sonnenhoehe < -6) && (sonnenhoehe >= -12) && (hour < 12)) {ON} else {OFF})
postUpdate(Sun_Dawn_Astronomical, if((sonnenhoehe < -12) && (sonnenhoehe >= -18) && (hour < 12)) {ON} else {OFF})
postUpdate(Sun_Dusk_Civil, if((sonnenhoehe < 0) && (sonnenhoehe >= -6) && (hour > 12)) {ON} else {OFF})
postUpdate(Sun_Dusk_Nautical, if((sonnenhoehe < -6) && (sonnenhoehe >= -12) && (hour > 12)) {ON} else {OFF})
postUpdate(Sun_Dusk_Astronomical, if((sonnenhoehe < -12) && (sonnenhoehe >= -18) && (hour > 12)) {ON} else {OFF})
Now, my logfile tells me the following:
2016-07-18 20:15:00.024 [WARN ] [o.p.j.i.JdbcPersistenceService] - JDBC::store: ignore Item ‘Sun_Dawn_Astronomical’ because it is UnDefType
2016-07-18 20:15:00.111 [WARN ] [o.p.j.i.JdbcPersistenceService] - JDBC::store: ignore Item ‘Sun_Height’ because it is UnDefType
2016-07-18 20:15:00.112 [WARN ] [o.p.j.i.JdbcPersistenceService] - JDBC::store: ignore Item ‘Sun_Dawn_Civil’ because it is UnDefType
2016-07-18 20:15:00.113 [WARN ] [o.p.j.i.JdbcPersistenceService] - JDBC::store: ignore Item ‘Sun_Sun_Azimut’ because it is UnDefType
2016-07-18 20:15:00.236 [WARN ] [o.p.j.i.JdbcPersistenceService] - JDBC::store: ignore Item ‘Pressure_today’ because it is UnDefType
2016-07-18 20:15:00.365 [WARN ] [o.p.j.i.JdbcPersistenceService] - JDBC::store: ignore Item ‘Sun_Dawn_Solar’ because it is UnDefType
2016-07-18 20:15:00.391 [WARN ] [o.p.j.i.JdbcPersistenceService] - JDBC::store: ignore Item ‘Sun_Dawn_Nautical’ because it is UnDefType
What is wrong with my items / rule?
