Hi all,
I have a strange behavior of Number items which contain numbers bigger than >= 10000.
My setting:
I have two Number Items, one defining a threshold, one holding a sensor value.
Number luminosity_min "Minumum Luminosity [%.0f]"
Number luminosityAverageGarden "Average luminosity garden [%.0f]"
Then I use it within a custom widget and compare the values:
<div class="box-content dummy" ng-style="{ 'background-color' : itemValue('luminosity_min') < itemValue('luminosityAverageGarden') ? 'darkgreen' : 'darkred' }">
if luminosity_min now gets updated to a number bigger than 9999 the comparison always is true, so the background never gets red. Going back to 9999 the comparison works as expected and the background changes according to the numbers.
Tested it also with a template widget and the following code:
{{ itemValue('luminosity_min') < itemValue('luminosityAverageGarden')}}
Same result. Given a value of 4000 for luminosityAverageGarden setting luminosity_min to 5000 will result in false, setting it to 15000 will result in true.
Interestingly, if both numbers are above 10000, the comparison works again.
Any idea, what the problem could be?
Thanks in advance,
Frank
