I am having a strange problem with a couple of shelly I4s.
The shellys should be used to trigger multiple scenes each by different button presses.
The problem now is that I am unable to trigger the same sequence twice in a row.
If I do a Short push it gets registered. But if I do a short push again it does not.
I first need to do another sequence to get it to register a short push again.
I tried using an expire to set last action to OFF after a couple of seconds. Sadly that did not help. It still does not register.
Did anyone else experience a similar behavior. Is there a way to mitigate this problem?
