Hi even more new
here the log of one time where it works, this i within a cpople och hours after a system start. Does anyone hav a clue of waths causing this?
2020-03-21 20:41:12.031 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@afcfe1.
2020-03-21 20:41:12.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:12.034 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:12.035 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-21 20:41:12.036 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-21 20:41:31.881 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 21 05 5B 03 77 00 03 F8
2020-03-21 20:41:31.886 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=33, callback=0, payload=00 21 05 5B 03 77 00 03
2020-03-21 20:41:31.888 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=33, callback=0, payload=00 21 05 5B 03 77 00 03
2020-03-21 20:41:31.889 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-03-21 20:41:31.890 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:UPDATE_NEIGHBORS)
2020-03-21 20:41:31.891 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Incoming command class COMMAND_CLASS_CENTRAL_SCENE, endpoint 0
2020-03-21 20:41:31.892 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-03-21 20:41:31.893 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Received COMMAND_CLASS_CENTRAL_SCENE V2 CENTRAL_SCENE_NOTIFICATION
2020-03-21 20:41:31.894 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 33: Received scene 3 at key 0 [Single Press]
2020-03-21 20:41:31.896 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-03-21 20:41:31.897 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CENTRAL_SCENE, value=3.0
2020-03-21 20:41:31.900 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Updating channel state zwave:device:dongle:node33:scene_number to 3.0 [DecimalType]
2020-03-21 20:41:31.903 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-03-21 20:41:31.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@e1e7f9.
2020-03-21 20:41:31.906 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:31.907 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:31.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-21 20:41:31.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-21 20:41:31.919 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 21 05 5B 03 77 00 03 F8
2020-03-21 20:41:31.922 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=33, callback=0, payload=00 21 05 5B 03 77 00 03
2020-03-21 20:41:31.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=33, callback=0, payload=00 21 05 5B 03 77 00 03
2020-03-21 20:41:31.927 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-03-21 20:41:31.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:UPDATE_NEIGHBORS)
2020-03-21 20:41:31.930 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Incoming command class COMMAND_CLASS_CENTRAL_SCENE, endpoint 0
2020-03-21 20:41:31.931 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-03-21 20:41:31.933 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Received COMMAND_CLASS_CENTRAL_SCENE V2 CENTRAL_SCENE_NOTIFICATION
2020-03-21 20:41:31.934 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 33: Received scene 3 at key 0 [Single Press]
2020-03-21 20:41:31.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-03-21 20:41:31.938 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CENTRAL_SCENE, value=3.0
2020-03-21 20:41:31.939 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Updating channel state zwave:device:dongle:node33:scene_number to 3.0 [DecimalType]
2020-03-21 20:41:31.943 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-03-21 20:41:31.944 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@36146d.
2020-03-21 20:41:31.946 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:31.948 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:31.949 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-21 20:41:31.950 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-21 20:41:31.953 [INFO ] [.smarthome.model.script.Remote Nodon] - Rule: Spotligt av via scen
2020-03-21 20:41:31.957 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 21 02 84 07 53
2020-03-21 20:41:31.961 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=33, callback=0, payload=00 21 02 84 07
2020-03-21 20:41:31.963 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=33, callback=0, payload=00 21 02 84 07
2020-03-21 20:41:31.964 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-03-21 20:41:31.966 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:UPDATE_NEIGHBORS)
2020-03-21 20:41:31.968 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Is awake with 2 messages in the queue
2020-03-21 20:41:31.969 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Start sleep timer at 5000ms
2020-03-21 20:41:31.971 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-03-21 20:41:31.999 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 21 02 84 07 53
2020-03-21 20:41:32.002 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=33, callback=0, payload=00 21 02 84 07
2020-03-21 20:41:32.010 [INFO ] [.smarthome.model.script.Remote Nodon] - Rule: Spotligt av via scen
2020-03-21 20:41:32.022 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 33: Node Status event - Node is AWAKE
2020-03-21 20:41:32.023 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-03-21 20:41:32.024 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5a35a2.
2020-03-21 20:41:32.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:32.027 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=33, callback=0, payload=00 21 02 84 07
2020-03-21 20:41:32.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-03-21 20:41:32.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:UPDATE_NEIGHBORS)
2020-03-21 20:41:32.030 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-03-21 20:41:32.031 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2a268f.
2020-03-21 20:41:32.032 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:32.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-21 20:41:32.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-21 20:41:32.034 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-21 20:41:32.035 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 21 02 80 02 25 91 F0
2020-03-21 20:41:32.037 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 33: Sending REQUEST Message = 01 09 00 13 21 02 80 02 25 91 F0
2020-03-21 20:41:32.038 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-03-21 20:41:32.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 2044: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 145
2020-03-21 20:41:32.050 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-03-21 20:41:32.051 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-03-21 20:41:32.053 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-03-21 20:41:32.055 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-21 20:41:32.056 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-03-21 20:41:32.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2044: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 145
2020-03-21 20:41:32.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-03-21 20:41:32.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-21 20:41:32.060 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2044: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 145
2020-03-21 20:41:32.061 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-03-21 20:41:32.062 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 2044: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 145
2020-03-21 20:41:32.063 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-21 20:41:32.064 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 33: sentData successfully placed on stack.
2020-03-21 20:41:32.065 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 2044: Advanced to WAIT_REQUEST
2020-03-21 20:41:32.066 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: TID 2044: Transaction not completed
2020-03-21 20:41:32.067 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-21 20:41:32.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-21 20:41:32.074 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Command received zwave:device:dongle:node13:
