Strange error when updating an item file
Please use code fences, I can see smart quotes and they will cause issues but unless u post in code fences it may just betheforum.
Btw do not exposeitems as that is not needed unless you use IFTTT as it will constantly use your internet even when not using a app or ui. Also best to keep The load on myopenhab as low as u can as it is a community runserver. The items at myopenhab will only update if u expose an item and then move the control. As mentioned do not expose any items just be sure to have remote andnotifications selected and then the tags do the rest.
